Replacing the filter on the Stillen CAI...
Old Sep 24, 2007 | 11:51 PM
mikeee2's Avatar
Hi all,
Hope everyone is doing well. Haven't posted for a long time. I placed an order for a Popcharger filter to replace my filter on the Stillen CAI. I know I could of re-oil it but a little skeptic about oiling too much and messing up the MAF so I bought a popcharger filter in the time being.
I have about 14k miles (1 yr 8 months) on the stillen filter. When do you guys change yours?
Also, do I have to take apart everything to put the popcharger filter in?
Thanks...
Old Sep 24, 2007 | 11:57 PM
Andy2434's Avatar
I use the popcharger on my Stillen airbox, as well. I usually change out the filter every 5,000 miles. Keep the K&N filter, which originally came with the Stillen set-up. You can clean the K&N when you have the time and take your time with the oiling process.
I normally remove the entire assembly to change out the cone filter. I disconnect the airbox with the MAF attached from the intake tube.
Old Sep 25, 2007 | 12:03 AM
mikeee2's Avatar
How long does it take you to put the popcharger in? It's been a while back but must of taken me an hour or so to install the stillen airbox or longer (I am slow...haha)
So I guess the steps are
-disconnect neg battery
-disconnect maf
-remove the whole assembly
-change filter
-reinstall everything
I forgot but a while back someone mentioned that the stillen cai might be banging the ac line under the box area and suggested to take the front wheel off and zip tie the bottom of the stillen box so it doesn't wobble. Gotta look into it.
Any good recommendation or steps to re-oil so I don't have to throw away the k&n filter?
Should of gotten the popcharger setup instead since it's so much easier changing it.
Thanks
derres
Aug 28, 2015 03:27 PM
Team STILLEN
Aug 10, 2015 08:17 PM
ClwMike
Jul 23, 2015 12:55 PM
vstypicals
Jul 20, 2015 10:55 PM
