JWT Pop Charger with Injen CAI Tube
Old Feb 18, 2004 | 11:19 PM
Coz@Czp's Avatar
Re: JWT Pop Charger with Injen CAI Tube
He Main Difference is the Velocity Stack (metal ring) for the JWT Pop Charger.
JWT POP CHARGER
This Velocity Stack helps improve air stability, thus makes a smoother flow without any high velocity disturbance.
Injen Intake
The Injen, also has a build in velocity stack, but as you can see, it's not very effective if you put the intake tube too far down the intake. You won't get such a smooth air flow with the Injen as you would with the JWT.
The Injen CAI works as well as the JWT intake, because it's outside the engine bay, and you get a lot more cold air into the car. The JWT sits inside the engine, and doesn't get as much cold air as the Injen CAI. Thank God for a heat sheild, other wise you would get NO HP gaines.
www.czp.us
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
AL8782
Oct 3, 2015 10:26 AM
dcsbh1
Oct 1, 2015 03:15 PM
