Kinetix Cats Installed... and please note...
Old Mar 14, 2004 | 07:55 PM
paintballbitch's Avatar
Ok I have my Kinetix Hi-Flow Cat installed... and it sounded awesome with my borla... Still have to install the Kinetix PLenum....
But my installer hit a snag with the cat... there is a cat plate that hold the 2 cats together, it cannot screw together with the 2 cats since the screw opening is too wide apart... my installer just have to make the opening a little big... not a big deal but anyone who is going to get the kinetix cat should know about it... I wish I had my camera at the shop...
I can't wait to have the plenum installed... once it is installed, I will record some clips for you guys =)
G35c, 5AT, NAV
INJEN CAI, Borla TD Exhaust, Grounding Kit
Kinetix Plenum, Hi-Flow CAT, Front Lip Spoiler
8000K HID, PIAA 7500K SPARK BLUE
Focal 165K2P, E10A.22, Eclipse HU, Nav-Tuner
Old Mar 14, 2004 | 08:53 PM
G35Newbie's Avatar
Re: Kinetix Cats Installed... and please note...
Congrats on the cats. I had the same issue on the mouting bracket. My installer did exactly the same thing like yours.
And yeah, Borla + Kinetix cats =
Borla exhaust, Nismo sway bar, Z duct, JWT p/c, Kinetix cats [img]/w3timages/icons/laugh.gif[/img]
Old Mar 14, 2004 | 10:12 PM
justICE's Avatar
If possible can you try to get a sound clip also? very interested in how the whole thing sounds.
Old Mar 14, 2004 | 11:00 PM
G35Newbie's Avatar
Here are a couple of vids from cryhavok's ride.
http://www.197358246.com/~havoc/DynoSmall.wmv
http://www.197358246.com/~havoc/G35CupdateSmall.wmv
cryhavok has the exact setup as I do except for the cats. He's got the R/T cats instead, but I wouldn't think there are much sound difference between the Kinetix and the R/T. My G sounds just like his [img]/w3timages/icons/cool.gif[/img].
Old Mar 19, 2004 | 03:16 PM
masetodd's Avatar
Is it necessary to have a shop install the cats? Or is it possible for a do-it-yourselfer?
G35 6MT/DG/Fully Loaded
[i]HyperGround Kit
350Z intake duct
K&N drop-in
Aluminum pedals
50%-35% smoke tint
Old Mar 20, 2004 | 12:41 PM
I think it is better to have a shop install the cat for you....
G35c, 5AT, NAV
Since it is quite hard to remove the stock cat and you will need to work underneath the car...
G35c, 5AT, NAV
Old Mar 22, 2004 | 08:05 AM
neffster's Avatar
I paid $34.75 this Saturday to have the RT high flow cats installed. I got to watch the entire install from beginning to end. The only "hard" part was getting to the bolts where the cat meets up with the header on the drivers side. There is all kinds of stuff in the way to get an air gun up in there. Also, with the RT Cats, there was no need to modify anything. No cutting or opening up anything, just needed to perform the install.
As far as a diy, I'd say it depends. If you really are the type of person that would take 2-3 hours to do this job yourself (come hell or high water) then go ahead. After seeing the install, I personally would not want to be laying on the garage floor trying to do it. The Y-Pipe is a different story though. Easy access and an easy DIY, but the cats are at least a degree more difficult.
2004 Infiniti G35C-6MT
LR | Willow | Premium | Aero | Splash | BSM
30% Lumar Tint | Invinca Shield (C-Bra)
Z-Tube | JWT Pop Charger | RT Cats
JIC Y-Pipe & Crawford Plenum (on order)
Old Mar 22, 2004 | 11:01 AM
cryhavok's Avatar
My installer ran into the same thing with the R/T cats. Instead of making the holes bigger, he bent the bracket using the extreme weight of the lift. Basically he let the lift come down on the bracket, which squeezed it a little closer.
Old Mar 23, 2004 | 06:51 PM
neffster's Avatar
Is the "cat plate" a gold U-shaped bar that attaches by 2 bolts to the car and 1 bolt (on each end) that attaches to the welded on arm of the cat? If so, my installer just loosley attached the two bolts holding the part to the car, and then attached each end of the U-shaped bar to the cats. No opening up slots or anything needed... hmmmm...
Crisci33
Jun 29, 2017 08:31 AM
magnetism80
Jan 27, 2016 12:57 PM
NJ6MT
Oct 9, 2015 05:02 PM
TrillO.G.35
Sep 5, 2015 02:06 AM
Julianpnce
Intake & Exhaust
Sep 1, 2015 07:41 PM
