Just installed my Test Pipes, hearing a rattling noise!! HELP!
Old Feb 12, 2008 | 06:18 PM
eckoultd87's Avatar
ok so I just installed my test pipes on my 06 G35 Coupe and im hearing a rattling noise when it revs in between 2k and 3k... i checked and everything is tight, it seems like its coming from after the cats...basically the y pipe.. anyone else have this issue??? any suggestions? thanks!
Old Feb 12, 2008 | 07:25 PM
Skaterbasist's Avatar
Retired SuperMod
Resonated or Non?
Either way, I'd say its rasp. What exhaust do you have?
Old Feb 12, 2008 | 08:34 PM
Bimmer G's Avatar
Will if you have just stock header's & exhaust with the test pipes. It's probably just the stock res. without the cats are makin it rasp.
Old Feb 12, 2008 | 08:57 PM
eckoultd87's Avatar
It sounds like its coming from the Y pipe...
I have stock Headers, test pipes, stock y pipe, stock resonator and stock exhaust.......
Old Feb 12, 2008 | 09:19 PM
Bimmer G's Avatar
does it sound like the heat shield or like the exhaust is vibrating
Old Feb 12, 2008 | 10:48 PM
eckoultd87's Avatar
No I took the heatshield off and rev'd it while in the air checking for leaks or anything loose and nothing. it's like a rattling noise at around 2k - 3k coming from inside my Y Pipe...
Old Feb 12, 2008 | 11:05 PM
Bimmer G's Avatar
Will with just the test pipes and my hks Ti exhaust it was a little rasy but when the borla header's went on i have a weird noise on right around the area your talkin about. I think your y-pipe vibrates when your around that rpm cause there's no resonator AkA cats to stop the noise.
Old Feb 13, 2008 | 12:34 AM
DaveB's Avatar
That's what a VQ with test pipes will sound like. It's the nature of the beast and it's firing order. Unforuntately, nothing is loose.
Old Feb 14, 2008 | 12:17 AM
bokchilo's Avatar
I have the EXACT same problem on my 07 6mt coupe w/ megan test pipes ... Does anyone think changing the Y pipe to a aftermarket one should fix the issue?
Old Feb 14, 2008 | 12:41 AM
eckoultd87's Avatar
Thats what I was thinking of doing... cause the noise doesnt come from the resonator, it comes from the Y pipe :-/ I hate this noise! i might just take off the test pipes and call it a day.....
Old Feb 14, 2008 | 02:21 AM
crashnburn's Avatar
sell them to me
Old Feb 14, 2008 | 10:52 AM
eckoultd87's Avatar
Originally Posted by crashnburn
sell them to me
I just order a new Y pipe so we'll see if the noise goes away... if not then i'll let you kno next week about the price for the Test Pipes
Old Feb 14, 2008 | 01:27 PM
G37Rider92649's Avatar
Haha you have rasp! I had rasps sooo much, went through 2 diferent cats/test pipes, went through 3 exhausts, I had so much rasp between 2k + they called me Rasp Master 2000 I settled now with a Fast Intentions full cat-back exhaust and Kinetix High Flow Cats, no rasp!
Old Feb 18, 2008 | 01:48 AM
bokchilo's Avatar
does anyone else have a 07 coupe with test pipes ? my "service engine soon" light keeps turning on even though I have non foulers installed ...
Old Feb 19, 2008 | 02:11 AM
nutt's Avatar
well i had my hks installed and there seemed to be the pipes hitting some part of the car so the guy put a 1 inch rubber thing in it and it seems 2 be working out. not sure if u have the same issue as me
