someone help me with intake installation
Old Feb 21, 2008 | 06:46 PM
elayman's Avatar
can someone please send me instructions + pictures for installation for AEM CAI? I am a noob and don't have the instructions since I bought it from another member. Thanks!!
Old Feb 21, 2008 | 06:56 PM
JOKER's Avatar
CLUB MODERATOR
put up pix of what you bought.
Old Feb 21, 2008 | 07:01 PM
elayman's Avatar
^i bought an AEM cold air intake. it has the long tube, the shorter bent tube, the filter, 2 bendable sleeve things (im bad with names) a bunch of fasteners, a filter, a water bypass thing, and a metal thing with 4 screws to attach to the plenum im guessing.. can someone just tell me how to remove the gtube and airbox?
Old Feb 21, 2008 | 07:06 PM
JOKER's Avatar
CLUB MODERATOR
G tube removes very easy
There is one screw by the plenum and rest are the hose clamps that you just loosen up and remove.
The air box is same way. I think there are two screws on it tho and then you just pull it up and it's out.
You can see it in this vid
Old Feb 21, 2008 | 07:13 PM
JOKER's Avatar
CLUB MODERATOR
One very important thing.
Be very very careful with Air sensor tube. It's that thing from which guy in the vid disconnects the wire harness from.
It's very easy to brake it (where it bolts up to the air box) and that fvcking thing cost $500 to replace. (tube is not sold separate from air sensor, that is why so expansive)
So when you pull air box out. Make sure that the hose is off that little plastic tube with sensor in it.
Also if you reuse any of the old hose clamps. Make sure you put them back in the grooves they were in in order to seal good
Old Feb 21, 2008 | 07:32 PM
elayman's Avatar
do you need the rubber thing that slides over the metal piece that goes into the filter? it makes it really tight and hard to put on, is this okay?
Old Feb 21, 2008 | 07:43 PM
elayman's Avatar
nevermind figured it out.. im running it short ram intake btw.. can anyone post me some pics of one installed correctly??
Old Feb 21, 2008 | 08:02 PM
gary c's Avatar
Intake install....!
Thanks to Joker it sounds like you're almost there. I have a Stillen intake so
it wouldn't be a help if I posted a pic. Make sure all clamps are snug and
your heat shield is installed. Wouldn't it be nice if someone would have made
instructions/pic available for your install? A company called MotorDyne is
about the only company that will give you good/informative instructions, and
that's just one of the reasons they're successful. Did you remove the negative side of the battery prior to install? Sorry I couldn't help you more!
Gary C
Old Feb 21, 2008 | 08:03 PM
elayman's Avatar
so i've got it set up to what i think should work, and it starts fine.. i ran it short ram and used the MAF sensor with the same MAF tube that came with the car, then attached the little metal piece from the intake into the filter adn thats it.. can anyone tell me if i did it right
Old Feb 21, 2008 | 08:04 PM
JOKER's Avatar
CLUB MODERATOR
Gary C
Better yet.
After install remove negative side of the battery and keep it off for 12 hours.
That will reset the ECU and you'll get a totally diff car after that.
Old Feb 21, 2008 | 08:05 PM
JOKER's Avatar
CLUB MODERATOR
sound like you did do it right.
Post pix
Old Feb 21, 2008 | 09:17 PM
elayman's Avatar
i didnt disconnect the battery at all, but am not getting a check engine light.. there is no heat shield with the AEM and i didn't want to pull my bumper back for the CAI so i ran it SRI
Old Feb 21, 2008 | 09:32 PM
elayman's Avatar
also when i was running it and driving around i hear a whistling noise.. kind of a "pssss" whenever i accelerate or rev the engine. is this normal???!
Old Feb 21, 2008 | 09:36 PM
JOKER's Avatar
CLUB MODERATOR
yes
That's the noise of air being sucked in through the intake
Still disconnect your negative from the battery overnight.
You got more air going into your engine now and ECU will take a while to adjust. But if you reset it it'll be much quicker. And your engine will perform better.
Old Feb 21, 2008 | 09:49 PM
elayman's Avatar
ok thx
