Injen CAI vs. Ztube/JWT popcharger
Old Apr 6, 2004 | 12:16 AM
SoCaLG35Mashin's Avatar
Re: Injen CAI vs. Ztube/JWT popcharger
like how?
04 G35 6MT Coupe
35% Madico smoke tint
CF Hood
Injen Cat-back
Old Apr 6, 2004 | 09:41 AM
cato's Avatar
SouthernComfort Moderator
I've had the Stillen HiFlow AirBox with the 350Z tube for about
nine months now. I have never heard the "whistle". All I hear
is the nice growl from the Z tube up to around 4000 rpm,
then the Stillen starts to howl. I also get a nice exhaust note
that was not there before.
2003 Twilight Blue 5AT Sedan, sunroof,
Graphite Leather, splashguards,
12 wire Hyper-grounding kit,
350Z intake duct, Stillen Hi-Flow Airbox
Underbody rear diffusers, Drilled aluminum pedals
Old Apr 21, 2004 | 07:17 AM
Sportcoupe35's Avatar
What has a higher whistle Or louder whislte??? Ztube or INJEN
2004 Ivory Pearl Sports Coupe
Old Apr 21, 2004 | 10:35 AM
cato's Avatar
Since I have never driven a G35 with the Injen, I could not say.
However, the Ztube by it'self produces no whistle, just an intoxicating
growl. Couple the Ztube with the Stillen, the growl turns into
a howl at high rpms, no whistle at all.
2003 TwBlue 5AT Sedan, sunroof,
Graphite Leather, splashguards, HKS exhaust,
14 wire Grounding kit, 350Z duct, Stillen CAI
Underbody rear diffusers, Drilled alum pedals<P ID="edit"><FONT class="small"><EM>Edited by cato on 04/21/04 07:38 AM.</EM></FONT></P>
Old Apr 21, 2004 | 11:33 AM
DaveO's Avatar
"Is the Stillen airbox with Z tube any better than stock?"
Yes, in my opinion. Both are good systems that incorporate a velocity ring, large cone air filter and heat shield into their design.
However, after a side by side comparsion, I believe Stillen's CAI is better than JWT's Popcharger. I like the JWT air filter design, but Stillen's heat shield is significantly better, IMO. The top, back and entire engine side of the air filter is totally shielded from engine heat and therefore "heat soak" during low speed operation.
The picture shows the velocity ring mounted through the Stillen heat shield to the mass air flow sensor. When mounted in place, the open side of the heat shield is against the driver's side inner fender.
Before flaming, please remember this is my opinion. You're entitled to yours.
DaveO - 2003 G35 Sedan / DP / Willow / AT / Premium / Sport
350Z Engine Cover, T-Stat & Air Duct / Stillen CAI
GG 7-Wire H-G Kit / TS ECU / E-Fans
Street Edge TC / B&M Cooler / Stillen Exhaust
http://233927-Stillen V-ring bolted ...ld to MAFs.JPG
Old Apr 21, 2004 | 11:40 AM
1crazmofo's Avatar
I've had the Z Tube/Pop Charger combo and just switched to the Nismo CAI...IMO the JWT heat shield does SQUAT. As long as the filter position is right in the engine bay, you will suck in TONS of hot air. Shield or no shield..Plus the shield looked like total crap. With a TRUE CAI, the filter position allows much more cold air than "short-ram". The great thing about the Nismo(AEM) is the by-pass valve in case the filter gets wet...No water ingestion potential...
Old May 6, 2004 | 04:35 AM
kelven33033's Avatar
same here....
i don't know which one to get...
Stillen HF, INGEN, or Z tube/pop
what's your conclusion
Old May 6, 2004 | 04:38 AM
does the mileage go down after you installed the intakee?
Old May 6, 2004 | 07:49 AM
Chops1's Avatar
Me and my buddy have almost the exact same setup except for the intake. I had the Stillen Air Box and he has the Injen CAI. He always had a strong pull on me and higher trap speeds at the drag strip. We dynoed within 2 hp of each other on back to back dynos.
So I broke down and got the injen CAI (thanks volksracing) and had the best 1/4 mile run ever on street tires, beating my old best by over .2 secs., and withing .06 secs of my buddies best time.
I am a firm believer in the Injen. I believe you can't get real world conditions on a dyno.
btw, we installed the Injen without taking off the bumper or the wheel.
Chops
chops's Avatar
Chops
ncg35guy
Sep 26, 2015 04:04 PM
dorkstar
Engine - Exhaust
Sep 9, 2015 07:43 PM
JG_G35
Engine - Intake/Fuel
Sep 7, 2015 09:35 PM
TrillO.G.35
Sep 5, 2015 02:06 AM
Tukeeg35
Aug 21, 2015 04:19 PM
