Removing Intake resonator
Old Apr 18, 2008 | 09:50 AM
ecko19's Avatar
If I want to remove the first intake resonator am I able to get at the bolt after I remove the airbox?
If you cant is there an easy way to do it?
Old Apr 18, 2008 | 01:24 PM
chumpboy's Avatar
I am not sure which bolt you are referring to since it has been sooooo long since I worked on mine but I remember it was all pretty straight forward. If you werent planning to do so, I would recommend you get a Z-Tube (intake tube from a 350Z) and replace the entire line. This will give you more of a grunt to the engine and will probably give you a few more ponies due to less restriction.
There is probably a how-to somewhere on line on who do it (I thought I remember seeing one way back when).
Ernie
Old Apr 18, 2008 | 01:34 PM
Cnkboy's Avatar
This might help.
http://www.6mt.net/mod-g35-350z-intake.php
Old Apr 18, 2008 | 01:56 PM
ecko19's Avatar
I was talking about the resonator directly under the airbox. I believe that you can leave it on if you put the a Z tube and pop charger on but I was curious if it was easy to pull it out.
Old Apr 18, 2008 | 02:53 PM
htownboy's Avatar
Pull it out, it's not hard, but save it somewhere to give to any future buyer who may want all the original parts.
Old Apr 18, 2008 | 03:46 PM
ecko19's Avatar
Well do you need to remove the wheel to gain access to the bolt that hold that in there or can you reach down vertically?
Old Apr 18, 2008 | 04:03 PM
htownboy's Avatar
I don't remember all details because it was 3 years ago; I do remember not having to take the wheel off, for sure...
Old Apr 18, 2008 | 04:08 PM
htownboy's Avatar
I called my cousin; he helped with this 3 years ago...
He said he remembers having to collapse the inner fender... It's plastic and bends out of the way so you can reach and get some hard to reach bolts. he remembers holding it out of my way while I worked on something hard to get to. The inner fender pops right back when you release it.
I hope this helps
Old Apr 20, 2008 | 10:53 PM
ecko19's Avatar
So no one knows what I mean when I talk about the resonator that is under the airbox?
Old Apr 20, 2008 | 11:39 PM
06CoupeDaddy's Avatar
You can get to it by turning the wheel hard to the right, jacking up the left side (or just do the entire front end by sliding a jack under the engine crossmember) so the suspension goes to full droop.
Then pull the little snaps out that hold the front part of the inner fender in and you can fold it down and back far enough to get to where you're going.
I'd have to ask though WHY would you only want to remove that part by itself, when there's another one farther back that hangs down off the intake tube. Go ahead and put up the $130 or so for the Stillen kit with the plastic (smooth) Z-tube. The stillen CAI is awesome. You can still use the ram-air part that sits over the radiator along with getting some SERIOUS growl outta' the G after the install. Might want to reset the ECU though when you do it. I've found it's not totally necessary as it'll 'relearn' the intake parameters as to air/fuel mixture it just takes a tank of gas at least. Easier to reset it with the Stillen kit and it'll be happy happy happy!!!
I've found it growls especially good when running premium gas... either that or pop in some octane boost here and there. I've ran 93 octane with octane boost and it'll SCREAM! Problem is... once it's used to higher octane it takes a while, like AT LEAST another tank for it to be anywhere near happy with 87 octane! Much easier to step back to mid-grade and just leave it there.
Old Apr 20, 2008 | 11:46 PM
O HELLA JDM's Avatar
you can take it out...its part of the g tube right of under the filter.... if ur using the g-tube just put some tape inside the g-tube to be ghetto to make it sound louder hhahaha
Old Apr 21, 2008 | 12:18 AM
nutt's Avatar
i really want to get an injen short ram intake but will i get a grawl as same as the ztube? i mean i know i get the sound of the air wooshing in but the grawl would be nice.
Old Apr 21, 2008 | 01:14 PM
htownboy's Avatar
I know exactly what your referring to and I removed all that crap a long time ago to install the AEM CAI... I did not have to take the wheel off or jack the car up, just needed a helping hand and did have to work on the ground looking up with a small 1\4 drive ratchet set. The resonator must go!
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
G35CO
Sep 4, 2015 09:27 AM
pasjr1972
Sep 1, 2015 10:17 PM
linedr89
Aug 17, 2015 05:11 PM
