True Flow Air Filters
Old Apr 28, 2008 | 04:53 PM
speedgeek's Avatar
Does anyone use True Flow Air Filters? They seem to have better filtration than K&N
http://www.trueflow.com/premiumairfilters.php
Old Apr 28, 2008 | 05:39 PM
Calvin's Avatar
Overglorified Altima
what makes you say that?
too lazy to look through the site.
Old Apr 28, 2008 | 05:45 PM
Jeff92se's Avatar
Red Card Crew
Having NO filter would flow more than K&N also. Point being, making it flow isn't hard. Making it flow AND filter dirt is hard. And traditionally, foam has turned out the very worst results in this regard. Well not as bad as the SS Blitz filter but who would run basicly a wire mesh for an air filter?
Old Apr 30, 2008 | 02:51 PM
SDGenius's Avatar
i'm running the Blitz SUS filter w/the pop-charger kit and it works great. they're really popular in Japan, they're not so popular out here because of the price.
Old May 1, 2008 | 11:12 AM
fortified's Avatar
Ouch!! $200+.....
read the test bottom of this page...
http://www.mkiv.com/techarticles/filters_test/2/
Old May 1, 2008 | 03:25 PM
Jeff92se's Avatar
Red Card Crew
What does "works great" mean? Flow? Maybe. Filtering ability? Can't be because these things only filter out small animals.
Old May 1, 2008 | 03:48 PM
SDGenius's Avatar
nah, i remember compareing the micron counts and it wasn't off by much. the crown is lower to cause that suction effect. it's used on a lot of turbo aps, so if it's clean enough for a turbo then it's clean enough for me.
Old May 1, 2008 | 03:50 PM
Jeff92se's Avatar
Red Card Crew
You did see that test right? The only thing worse was the HKS foam filter. Which is also used by turbo guys.
Just because it's used by turbo guys doesnt' mean it's a good filter. They might use it because it FLOWS. Not because it filters decent. Which it does not.
Old May 1, 2008 | 03:52 PM
SDGenius's Avatar
okay, well can you send me a link to this test??? thanks
Old May 1, 2008 | 03:54 PM
Jeff92se's Avatar
Red Card Crew
no need. Post #5
Old May 1, 2008 | 07:56 PM
SDGenius's Avatar
thanks
Old May 1, 2008 | 08:02 PM
redlude97's Avatar
I don't understand how the apexi can have zero maintenance? The dirt has to be collecting somewhere
Old May 1, 2008 | 08:06 PM
Jeff92se's Avatar
Red Card Crew
Because the Apexi is a throw away filter. No maintenance! It flows well and filters well. But you gotta buy a new one every time.
Old May 1, 2008 | 08:18 PM
SDGenius's Avatar
it's say's it's a lifetime use filter
Old May 1, 2008 | 08:24 PM
Jeff92se's Avatar
Red Card Crew
It could be their version that you clean by blowing air though the back. Dunno
