i need help!! my idle is high
Old May 29, 2008 | 07:06 PM
infam0usndn2nv's Avatar
hey i just installed my aam angled plenum spacer....i followed the instructions....but when i was done with it i started the car my idle was at 1k and my check engine light came on i went to autozone to c the code....
1 vacuum leak on engine
2dirty throttle body ( I CLEANED IT B4 I PUT THE PLENUM ON IT)
3iac motor defective
4poor electrical connection to the iac motor!!
can some 1 plz help
Old May 29, 2008 | 07:44 PM
BlueDevilBAMF's Avatar
sounds like you either forgot the gasket or the gasket isn't sealed properly
Old May 29, 2008 | 10:18 PM
i need helpPPPPPPPP
Old May 29, 2008 | 10:52 PM
G37Rider92649's Avatar
+1
Also i suggest you to reset your ecu so it can learn your new mod, and in the mean time of learning your idle can be weird, i remember i installed test pipes and headers and my car stalled at start up for 2 weeks, and my idle was weird, but after that it went away.
RichardxG35's Avatar
recheck all the hose youhave disconnect
Old May 29, 2008 | 11:41 PM
i didnt reset the ecu i checked everything else!! it is good.....but how do i reset it??
Old May 30, 2008 | 12:40 AM
One surefire way is to unplug your battery overnight.
Old May 30, 2008 | 12:56 AM
Red_G35's Avatar
Double check to make sure all your harnesses are clipped together. good luck!
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
the93owner
Oct 4, 2015 09:40 AM
vamarris
Sep 26, 2015 12:56 PM
