Which Intake To get ? HKS or Nismo??
Old May 30, 2008 | 05:37 PM
  #31
Jeff92se's Avatar
Red Card Crew
I looked very close. The Biltz is clearly is letting alot more dirt into the ENGINE vs the others except the HKS.
It doesn't matter WHICH car the test uses. what matters is the relative results against various filters. The results speak for themselves.
What you should be concerned about is WHERE this dirt is going. It's going straight into the combustion chamber and sandblasting your cylinder walls. And contaminating your oil.
At least the Blitz looks pretty. Ever wonder why the blitz has no maintainance? Because it's not catching anything to get the filter dirty
Here is a summary of the point of the test:
Therefore, in the quest to find the ultimate induction kit, the filters must not only filter the particles out efficiently, but must maximize the amount of clean air flow, through the filter. The winner would be the induction kit that filters the most dirt particles, whilst acheiving the maxmimum power output of the vehicle.
Doesn't that sound like a reasonable objective?
Old May 30, 2008 | 05:39 PM
  #32
G37Rider92649's Avatar
screw an intake, replaced it with my inter cooler piping when i went booooooooooosted...save up and get boosted guys, seriously, our cars are freakin slow i got wooped enough
  #33
SDGenius's Avatar
the same style of filter the HKS uses has been used in MotoX forever, it hasn't stoped any of them from ridding. yes, the blitz doesn't filter out everything... niether does the stock filter or any filter for that matter. i've always liked the APEX'i filters but they don't make on for the G, unless you have a CAI setup. this filter isn't gonna kill my engine, i've been assured by many reputable mechs. not just some guy who found a random article one day.
Old May 30, 2008 | 05:42 PM
  #34
redlude97's Avatar
+10000000
Old May 30, 2008 | 05:45 PM
  #35
officerdbag's Avatar
wtf? haters? Who's hating?
Your glorifying your intake like its gods gift to man and you're expecting everyone to praise it. Heat sheilds DON'T WORK! They. Do. Not. Repel. Heat. Away. From. The. Filter. They're merely for show.
As for fujita losing 15+ HP.. Please show me any sign of that because now you're talking out of your a$$. Only way that would be possible is if the car had a blown head gasket and was completely detuned.. Its almost impossible to lose that much HP from an intake.
You don't even have a dyno of before and after from stock to your intake set up.. How are we supposed to believe you? You felt a power increase cause of the noise right? That must mean you gained hp.
No one is getting butt hurt, if anyone its you.
  #36
Jeff92se's Avatar
Red Card Crew
LMAO. You think because it won't "kill" your engine right away = okay.
It's not about filtering everything, it's about maintaining the max amount of flow with the max amount of filtration.
Just for your information, people that race care about winning, not filtration. They teardown and rebuild their engines quite often.
At LEAST run a blackstone labs test on your oil and observe the silicone content reading.
I did that with my Stillen/K&N setup on my maxima. Results came back good.
Old May 30, 2008 | 05:46 PM
  #37
Yo, you want boost my G too? I'll pay you back monthly
Old May 30, 2008 | 05:48 PM
  #38
I also have to agree with jeff here.. The filter in usmcmark's pic looks like a coffee filter.. Look how thin that crap is.
  #39
Jeff92se's Avatar
Red Card Crew
Don't know about losing that much across the board. But it would be very possible to have an ill-designed filter to lose that much in particlar rpm range.
Just for your information, it's alot easier to make a filter that loses power than it it is to design one that actually makes power. Especially on our well designed VQ35 motor.
Old May 30, 2008 | 05:49 PM
  #40
SDGenius's Avatar
i lived in Japan for 2yrs, i've met guys who've ran these filters on their rides forever. Turbo kits shorten the the lifespan of ur engine more than anything. hell just driving it hard will. it's not made to last forever. if that's what ur interested in, go buy a Toyota Corola. if not then keep ur car, push it and have fun while it lasts. then get a new toy.
  #41
I can guarantee you I didn't lose 15 hp with my fujita.. Didn't feel any gain or loses
Old May 30, 2008 | 06:00 PM
  #42
Jeff92se's Avatar
Red Card Crew
Um no. Your logic is crazy. If I can have flow AND FILTRATION, why should I have to put up with all the dirt going into the engine?
Sorry the bling factor isn't THAT important to me. Call me crazy but when you have a filter, I expect to do what? Filter maybe?
Turbo kits only shorten the life of the engine if you treat it wrong. But at least there's a benefit to justify the risk.
Old May 30, 2008 | 06:01 PM
  #43
Jeff92se's Avatar
Red Card Crew
I'd be interested in a dyno sheet that's NOT from fujita if you have it. The one from there site is a joke IMHO
Old May 30, 2008 | 06:06 PM
  #44
SDGenius's Avatar
no, i'm not glorifying my intake... they guys asked about it. you can say they don't work BUT ur running a setup that lays the filter right on top of the engine, that DEF DOES NOT WORK. and if you knew a little more about ur car then you'd know that you can loose a lot of power from poorly designed parts. do some reseach, i did. BTW, you can lose that much HP on a really hot day... now imagine it's always a hot day under u hood.
no, it's not a gain from the sound it's a gain from the Dyno sheets i got at Technosquare. no, i don't have a stock dyno sheet. just a pre & post tune one. they on the other hand did have a stock G 2003 sedans sheets from there dyno and it was around 210ish to the wheels(mostely because of the older 5AT). mine was 246whp, they said that on another dyno on another day they're sure it'd be much higher. the tune alone picked up 18whp. i'm not tryin' to say my car's the best BUT i do take it seriously.
Old May 30, 2008 | 06:16 PM
  #45
SDGenius's Avatar
just one comparison i found really quick
http://www.envisionelite.com/intakes.html
