home made z-tube (test)
Originally Posted by ichiban101
what exactly is that comment supposed to mean? can u be more specific please?
just me reading into this, "ricer" meaning "oriental", "japanese" perhaps?
who do you think designed and manufactored these vehicles?
and to anyone else who feels that "his" comment was not helpful,...let's not entertain him
I just don't understand, you buy a $30k+ vehicle, then want to put a $10 piece of plumbing/drain material on it just to save 20-30$ .
Originally Posted by IVRY PRL
Do you mind telling me how long the 3" piece was? Reason I ask, is I can get one made up for free at work from aerospace grade aluminum as long as I have the dimensions.
and i took the advice of painting the tubing black...
Originally Posted by ShanesG
WHAT?
I wonder how this would compare to the real Z tube. My thoughts is they would probably be close to the same, but the PVC pipe is probably thicker than the Z tube thus making the home made intake a tad bit narrower. I guess there is no way to know for sure unless you were to dyno both for a good comparison.
not my cup of tea, but if it works for you then I applaud your efforts.
WHAT?
FYI...i'm 47 yrs old. i work for a major coffee plant here in new orleans. my gross income is "more than enough" to purchase a authentic z-tube if i so desired, and then some.
what i have done is not to save on $$$, but to fabricate the tube, test it and kill time mostly.
some people like to tinker. now do you understand?
and the tubing i used has a wall thickness of 1/16" and the I.D is the same as the 45* fitting on the throttle body, a very smooth transition. so i don't beleive there is a restriction. i haven't physically seen a authentic z-tube, but if it is made from the same material as the stocker, then the pvc is more than adequate
^ no i understand, if you want to creat a tube that is awesome, but buying PVC and cuting it is not fabricating a intake. You just installed a cut piece of plumbing material...
question...what is a z-tube? clearly not a entire intake system. but just a "tube" redisigned without the air baffle chambers
