aftmkt mid pipe and catback, with stock rear section ??
Old Aug 9, 2008 | 07:55 PM
maxspeed96ct's Avatar
I want some more power from my G , But do NOT want it loud at all.
I'm wondering how it would sound with a aftermarket y-pipe, midpipe and and catback, but id leave the part behind the axle stock.
The muffler seems to me like it flows good, and gains come from increased piping size , flow and removal of the huge canister in the back.
What do you guys think?
anyone running a similar setup?
Old Aug 10, 2008 | 11:49 AM
bump
anyone else ?
Old Aug 10, 2008 | 03:16 PM
sloppymax's Avatar
I am running berk hfcs, tanabe y pipe going into the oem midpipe. I had the HKS rear section but after the hfcs, it was just too loud. I put the oem rear section back on and you tell it is not stock but it is not obnoxious either. I have given thought to picking up a coupe midpipe, getting an additional hanger welded on and seeing how much louder it is. I do not have any sound clips but I will see if I can scrounge some up. I could stand an small increase in sound but trying to stay under what the HKS sounded like.
Old Aug 10, 2008 | 06:46 PM
jimmykce1's Avatar
I would suggest just getting Berk Tech HFC and keep the rest stock for 05/06 sedan.
Old Aug 10, 2008 | 09:27 PM
I want the sound your talking about, not obnoxious but lot too loud
did u notice a good gain after the HFC's ?
Do you have a aftermarket y-pipe ?
Here is what my previous 02 maxima sounded like, it was fun but i dont want anything nearly as loud.
Old Aug 10, 2008 | 09:32 PM
sloppymax's Avatar
i did feel a little but how much i am not sure. i got a dyno done at about 8k miles with only a MD spacer and that shop closed down so i cannot reuse the same dyno. i have a tanabe y pipe, it was the only y pipe i could find that would closely match the stock midpipe inlet. the hks y pipe was a tad smaller and better fit for the stock midpipe but no vendors i emailed could get their hands on it. every other y pipe was a 3" outlet and i did not want to create blockage when i put that up to the stock midpipe.
Old Aug 10, 2008 | 09:43 PM
Ya i was about to order the y-pipe. I see the cheap ebay ones have smaller inlets.
Do you remeber your peak hp and tq numbers ?
Old Aug 10, 2008 | 10:30 PM
sloppymax's Avatar
SAE on a dynojet model# 248 was 227 hp and 214 tq. Std correction was 232 hp and 220 tq. All pulls were done in 4th. I am positive it has more power now and hopefully I can find another dynojet 248 to do some runs on.
Old Aug 11, 2008 | 03:37 PM
was that stock or after the mods.
Those numbers seem low, unless its cause your a auto ?
Old Aug 11, 2008 | 04:35 PM
sloppymax's Avatar
those numbers are with the 5/16 manifold spacer only at 8k with dino oil. i am not one to put up a list up things why i thought the numbers were low because dynos have always humbled me. if there were two contributing factors i would say the car did not have much mileage on it and other cars were dynoing lower that day than they said was typical. my a/f was pretty clean so i was happy about that. the auto is obviously less efficient at getting the power to the wheels than the 6 speed. i plan on making some rockingham passes and some dyno pulls in the fall. i have been giving thought to going the Osiris route but can hopefully make a decision before much more time passes.
Old Aug 11, 2008 | 09:39 PM
o man dont tell me about mileage, I used to spank my buddies 07 hr auto g35x , not that im still at 6k and hes at 15k he spanks me..
i dunno if its his intake, or my car need to break in.....
I started driving my g more now ...
Mechanic buddie of mine said around 10 -20k the car will shine even more....
I hope hes right ...
TWASkyliner
Feb 8, 2020 08:00 PM
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
johnjohn077
Engine - Exhaust
Oct 2, 2015 06:41 PM
nascarbuff17
Jul 16, 2015 10:23 AM
