problem after installing samco radiator hoses
Old Sep 1, 2008 | 07:20 AM
fabcas311's Avatar
well after my shop did the install..........
i noticed a high pitched sound in the engine just like when you turn the A/C on full blast.......but A/C was turned off at that time as i was driving home.
then today driving to work...same sound on the engine....with the temp. guage reaching 3/4 at one time........than back to normal.... .....i was so scrared that i almost stopped in the middle of the road.... .......cruising at just 30-40mi.....when i parked my car...engine is not that hot.....no smoke..or cooking smell
i wasnt able to open the radiator cap,afraid of hot molten liquid spurring in my face ...and got no time since i had an emergency in the hospital....
thanks
fabiene
Old Sep 1, 2008 | 08:50 AM
SFLG35's Avatar
FGC President
sounds like there might be an air bubble in the system
Old Sep 1, 2008 | 10:54 AM
k67p67's Avatar
Very likely air in the system. Our cooling systems are notoriously-difficult to bleed. The process is both time-consuming and tedious. Cycle through a/c-heater-fan repeatedly. Turn off engine periodically and purge air from bleeder screw (hose in front of firewall on passenger side). Make sure coolant overflow resevoir level is maintained. Usually takes me 30-60 minutes (unless you have a special funnel).
Old Sep 2, 2008 | 08:41 PM
fabcas311's Avatar
wow!thanks for the heads up!problem fixed!
Tukeeg35
Cooling
Oct 20, 2016 04:14 PM
saskicker32
Aug 11, 2015 02:12 PM
Smittie20
Aug 9, 2015 04:29 PM
joedaddy1
Jul 28, 2015 02:58 PM
lemmy999
Jul 25, 2015 12:13 PM
