New intake choice
Old Sep 10, 2008 | 02:33 PM
Jeff92se's Avatar
Red Card Crew
I reviewed the test that showed the restriction vs dirt.
But where is the data for filtration? Teh site claims #1 in filtration.
Old Sep 10, 2008 | 02:37 PM
OCG35's Avatar
I'd like to see how the heat shield connects to the snorkel (inlet above core) support)... is the intake tube available alone? Or does it require the purchase of the heat shield?...
Old Sep 10, 2008 | 02:38 PM
OCG35's Avatar
Originally Posted by PFE
Thanks OCG35.
We retained the air inlet above the core support on the Infiniti G35 applications. It's not an ideal air source but it can't hurt.
Regards,
PFE
what option for cold air source is there on the first gen Gs?...
Old Sep 10, 2008 | 02:50 PM
5150DS's Avatar
Thanks OCG35.
The tube will not adapt to any other aftermarket products that I'm aware of.
If you would like to see actual lab test results comparing the R2C with JWT, Stillen/K&N or others, let me know.
Regards,
PFE
Do you have pics of the G35 setup on a G35.
Old Sep 10, 2008 | 02:59 PM
PFE's Avatar
PFE
Dust pass through testing
I have attached a few more tests and the protocol. Our mandate was unmatched efficiency and engine protection. That was fairly easy. It required months of engineering the filter media in terms of fibers and voids in order to produce the lowest restriction levels over the entire life of the filter in conjunction with this level of fiiltration. No compromises.
Jim Wolf Technologies
Initial Efficiency 92.2%
Cumulative Efficiency 93.6%
Fujita
Initial Efficiency 52.8%
Cumulative Efficiency 47.5%
R2C Performance PowerFlow
Initial Efficiency 99.1%
Cumulative Efficiency 99.5%
I have many other tests that illustrate dust holding capability, although the capacities are not even close.
Regards,
PFE
File Type: doc
Old Sep 10, 2008 | 03:02 PM
ShanesG's Avatar
pretty cool but $400 for a intake, DAMN!
Old Sep 10, 2008 | 03:27 PM
5150DS's Avatar
You gotta respect how they back their statements up with numbers.
Old Sep 10, 2008 | 03:32 PM
PFE's Avatar
PFE
R2C Performance
ShanesG,
It's certainly an extremely expensive product to produce. We didn't buy a piece of round tubing and have it bent. That would have been easy and relatively cheap. It also doesn't work very well. We could have produced filters on par with the existing group but that wasn't the motivation. If Infiniti/Nissan owners truly realized how much work this filter performs each day and remembered that it's single purpose is to protect the engine from micron sized particulate, they would understand that a better choice is vital.
Particles ranging from 0-10 microns routinely sandblast the cylinder walls of your G35. The repercussions of this will manifest themselves over time. Not to mention the impact on motor oil. There are roughly 300,000 microns in a foot. Take a look at the piece of cotton gauze with the glue on it and ask if this can be effective?
The R2C filters last as long as the car. Not one penny is spent on hazardous filter cleaners or oil over the life of the filter. How much is this process? ( if it's actually performed). No down time waiting for the filter to dry.
1 System - Specifically designed!
1 Filter - The best available!
No cleaner or service ( low pressure air cleans the filter)
No filter oiling kits ( The MAF and carbon systems say thanks!)
It's also priced well below $400 by most of our retailers. I'd say it's a pretty good value based on competitive comparisons. Please ask any questions you may have?
Avoid The Use Oiled Cotton Gauze Or Foam Filters
Sincerely,
PFE
Old Sep 10, 2008 | 03:39 PM
ShanesG's Avatar
any sound clips? Dyno sheets? Etc.
Old Sep 10, 2008 | 03:49 PM
wreaks's Avatar
Any applications for the '07 and up G35 sedans. Why not consider and OEM style replacement filter for those of us who like the stock intake.
Old Sep 10, 2008 | 03:50 PM
PFE's Avatar
PFE
R2C Performance
I'll provide the quality air. You use it to the best of your ability!
Asthma gone! Constipation, that's another story!
Each dyno test will be unique. We don't manipulate these things. Imagine what approx. 60% less air inlet restriction will do for you provided you can effectively consume the new volume. The processor does a pretty good job of making sure things are balanced regardless of how much we provide at part throttle/cruising. Full boogie is up to your configuration. Let the air pump breathe!
PFE
SEMA booth 21923
Old Sep 10, 2008 | 03:53 PM
5150DS's Avatar
What I think you should do is give me one so I can test it out and report on how I like it.
Old Sep 10, 2008 | 04:02 PM
PFE's Avatar
PFE
R2C Performance
Thanks Wreaks,
All Nissan/Infiniti 350Z/G35/G37 filters and systems are available. It will take a few weeks to ship.
We are considering a stock air box filter but it's important that we maximize any opportunity the factory air box provides to us. The patented tube design required so much time designing and engineering each transition and facet that it's hard to forsake it and the performance gains by offering a factory box replacement although I do understand there is a demand for this. When it's ready, it will provide as much improvement in restriction and engine protection as the box will allow.
The original filter is much better in terms of engine protection than most of the competitive performance filters available. It's quite restrictive though, especially when light loading occurs.
Sincere Thanks
Old Sep 10, 2008 | 04:05 PM
JOKER's Avatar
CLUB MODERATOR
yeah I was gonna suggest the same thing.
you deff need few "satisfied" clients out there to spread the good word
so how bout it PFE?
I'm ready to PM you my address.
I'll even send you pictures of my cleanest stock engine bay that you can use on your site for G35 application.
Old Sep 10, 2008 | 04:12 PM
  #30
PFE's Avatar
PFE
R2C Performance
These systems have logged so much street and track testing time that we're wearing the cars out! I have filters so full of test dirt their tough to lift. We had a dirt track modified run 300 laps without touching the filter. It still outflowed the others. I don't recommend this!
Maybe one of those vehicle wraps with the R2C logo all over the car in exchange?
Send the engine compartment photos. We'd all like to see the cleanest G35 around. I'm picky though!
Sincerely
PFE
