Injen exhaust
Old Oct 7, 2008 | 02:27 AM
repin_LB's Avatar
Injen exhaust
I had a question about the Injen exhaust. So pretty much i decided on the Injen Exhaust after hearing many many sounds clips and LOVE the sound. But the only issue now is between the Titanium (blue tip) compared to the regular. What is the difference? im guessing one the look and second the TI is lighter...anything else?
Old Oct 7, 2008 | 03:40 AM
O HELLA JDM's Avatar
no difference... its only a ti tip...its burnt yea... no weight difference i had teh injen track ed. with ti tips...
Old Oct 7, 2008 | 03:47 AM
TaiMonkey's Avatar
if you want a used one let me know. I added an extra set of resonators to keep the droning noise down.
here are some pix.
let me know
http://losangeles.craigslist.org/sgv/pts/861895492.html
Old Oct 7, 2008 | 04:03 AM
repin_LB's Avatar
whats droning noise anyways? and i was going to ask what resonators are but i guess it keeps the droning noise down??
here are some pix.
let me know
Old Oct 7, 2008 | 06:08 AM
TaiMonkey's Avatar
drone noise is the deep exhaust noise in the cabin. since this exhaust has a very deep tone there is also a corresponding cabin noise. the extra set of resonator help keep the deep tone in the cabin at a reasonable level. I can say that from my experience the deepest sound comes from 2k-3k rpm. when you cruise highway it is fine.
Old Oct 7, 2008 | 06:12 AM
TaiMonkey's Avatar
you can also go to injen website
http://www.injen.com/galleries/produ...T_floating.jpg
the picture shows a H-pipe, two muffler, and two middle pipes.
In my picture you can see that i added two resonators in the middle pipes.
Old Oct 7, 2008 | 07:27 PM
repin_LB's Avatar
also i was listening to the z injen systems...will those exhaust have the same noise as the g's injen system?
Old Oct 7, 2008 | 08:54 PM
TaiMonkey's Avatar
yup. same same... the difference between the z version and g version is that the G injen version is about 3-5 inch longer than the Z version. but most people can fix that issue by buying an extension.
http://www.thenismoshop.com/ikorb.ph...oduct_id=12663
so if you find a 350z exhaust you like. then just the extension with the same pipe diameter. or you can have a shop extend it.
honestly, if you want something super clean and pretty you should get a new one.
if you dont care that much about looks and want it for performance. then you can buy used ones. like mine. ... anyways if you want it. i can do it for 500 cash firm ... local pick up... you know you should pm me so i know faster.
Video Share
Jan 31, 2017 04:00 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
dorkstar
Engine - Exhaust
Sep 9, 2015 07:43 PM
