Test Pipe Check Engine Light Help
Old Oct 22, 2008 | 12:49 AM
1sick740's Avatar
my friend has an 04 coupe. he had some kentix test pipes installed today and the test pipes had a place for the o2 sensors and we installed those but there was also a smaller hole drilled at the top of one of the test pipes. For what...im not sure but we had it welded over. Now after about 50 miles of driving his check engine light is on due to emissions. The computer says it could be the filler cap but its not that so im assuming it has to do with the test pipes..what is wrong..thanks
Old Oct 22, 2008 | 12:52 AM
06g35meister's Avatar
youz need these:
First off, for those who don't know, you need to buy TWO pairs of the non-foulers. One pair needs to be drilled out with a 1/2" drill bit (Most drills can't hold this bit, look at the pics of the drill I used... its over 30 years old). Once one set is drilled out, you take a drilled non-fouler and screw it onto the O2 sensor. Then take the NON-drilled one and screw it onto the DRILLED one. So the order goes, O2 sensor-->Drilled-->Non-drilled-->test pipe/cat. Once you go to do the drilling and everything, the order makes sense.
Old Oct 22, 2008 | 12:53 AM
i have an extra set i can send you for like $20, they cost me $10 and itll cost 5 to ship and some in gas.
Old Oct 22, 2008 | 12:54 AM
see this:
http://my350z.com/forum/engine-drive...-fix-pics.html
Old Oct 22, 2008 | 01:51 AM
1sick740's Avatar
where can i buy some locally
Old Oct 22, 2008 | 01:53 AM
Calvin's Avatar
Overglorified Altima
pep boys
Old Oct 22, 2008 | 01:55 AM
1sick740's Avatar
thanks guys...so i should get 2 sets one for each cat?
Old Oct 22, 2008 | 01:56 AM
Skaterbasist's Avatar
Retired SuperMod
Yep
Muski_G
Dec 1, 2023 11:11 AM
Jay 21
Aug 5, 2015 04:53 PM
ClwMike
Jul 23, 2015 12:55 PM
Jadenkid22
Jul 14, 2015 12:33 AM
