Z-Tube or Not to Z-Tube - Opinions Wanted...
Old May 26, 2004 | 02:50 PM
jjellyneck's Avatar
Re: Z-Tube or Not to Z-Tube - Opinions Wanted...
The Z tube is a simple and effective mod. It was the first one that I did. By itself with everything else stock, I could tell that there was slightly less fall-off of power in the very high RPM's. Just barely enough to tell, but enough to make the mod worthwhile (it took me 10 minutes to install, including putting the tools away).
'04 6MT coupe
Old May 27, 2004 | 11:32 AM
ChicagoX's Avatar
Don't drink and Mag Race
Z-tube is best bang for buck IMHO.
I would also recommend highly the K+N filter. The only (extremely rare) problems I've ever seen are with user error over-oiling due to the unclear instructions in the kit. The flow increase over stock paper elements is nothing short of phenomenal.
'04 G35X Graphite/graphite, NAV, wood, premium
Old May 28, 2004 | 12:22 AM
Kenboyb's Avatar
i have one thing to say.................. injen
Old May 28, 2004 | 09:51 AM
SFLG35's Avatar
FGC President
if you like holes in your ac line and loss of hp then injen it is.
Daniel
5ATC / DP / Willow / Premium / Aero / Clear Bra / 5% Tint - 30% Windshield / Ground Kit / Clear Corners / Shock Sensor / L.E.D. Hood Lights / Z - Tube / OEM Remote Window Up / VDC Memory
Old May 28, 2004 | 02:42 PM
Catatafish's Avatar
I've had 3 different intakes on my car and the Nismo (similar to the Injen) is miles farther from the A/C line than my Z tube/JWT Pop. Whether it rubs has more to do with the quality of attachment at your throttle body. 1 MM at the throttle body makes a 1/4 diff at least at the A/C line.
I could also measure no differences in HP between the 3 with my G Tech Pro Comp, margin of error about 3 HP.
My decision ended up being "which I preferred to look at with the hood open". I ended up Nismo cause that shiny black tube and emblem look great with the black plenum. It should complement the red Samco hoses well too.
2004.5 Coupe/5AT/Ivory/Everything but front spoiler/Nismo CAI/Crawford V5
Marlin84
Apr 1, 2020 12:52 PM
jeffbdye
Jun 1, 2018 03:51 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
