Z tube with K&N filter
Old Jun 2, 2004 | 11:28 AM
artmansr's Avatar
i replaced the OEM air box with the pop charger and z tube, i was wondering if it is possible to install the OEM air box with the z tube? do i have to modify the air box or anything? i want to do this to see if i can gain some of the low end torgue back...
Old Jun 2, 2004 | 11:45 AM
KAHBOOM's Avatar
Re: Z tube with K&N filter
The OEM air box fits fine with the z-tube
2003.5 G35C 5AT
Premium Package
Tire/Wheel Package
K&N Filter, Z-Tube, EGK
Old Jun 2, 2004 | 12:00 PM
skaline's Avatar
Fits no problem. Try removing the resonator on the bottom of the OEM air box before you re-install it for some extra growl.
My 350GT
Old Jun 2, 2004 | 01:56 PM
artmansr's Avatar
sorry for sounding,, dah! what is the resonator, is that the box that plugs into the hole that you see when you remove the OEM system to replace it with an aftermarket? if you have done this, did you replace an after market CAI or went straight to the OEM and Z/k&N?
Old Jun 2, 2004 | 03:08 PM
skaline's Avatar
This is it, Just take it off of the OEM airbox. You may want to plug the hole at the bottom of the airbox once it's ben removed. Check out this thread for more info
My 350GT
Old Jun 2, 2004 | 03:31 PM
artmansr's Avatar
thanks for the thread and pic....reason i want to do this is to get more low end torque, but reading the threads i've concluded that it growls better but not a better response than an aftermarket. I may be incorrect about this thoe...
Old Jun 2, 2004 | 07:46 PM
GRider35c's Avatar
i think the primary purpose of that is to trap large dirt particles and junk so that it doesnt get in the way of the air filter... i highly recommend not to remove this piece. although removal will make the engine sound louder, it will also make the air filter much dirtier and trap more particles, needing to clean it more often...
i have the K&N drop-in and am getting the Z-tube in 2 days, im leaving that "resonator" in...
04/BO/G/aero/splash/prem/perf/cc/22%tint
Old Jun 2, 2004 | 10:07 PM
KAHBOOM's Avatar
Yeah I kept mine in... I vacumed out my stock air box because it was still full of dirt and junk... I would leave it as I do not think that any gains in sound or performance are worth it.
2003.5 G35C 5AT
Premium Package
Tire/Wheel Package
Picture Share
Feb 4, 2018 12:41 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
