Bit the bullet, got the MD 5/16th spacer
Old Dec 12, 2008 | 01:33 PM
  #61
AARONHL's Avatar
This thread is making me itch for a 5/16"!!!!
Old Dec 12, 2008 | 01:49 PM
  #62
PAIXAO's Avatar
Originally Posted by Hydrazine
Supposedly, but there isn't a 38 HP difference. It was for marketing reasons that they rated the 04 Sedan so low. Even though it had the exact same engine as the 350Z in the same year, with the same power. Infiniti rated it lower.
At least on paper, they didn't want the Sedan to have the same power as the Coup or the 350Z. So they under rated it.
I have both a 04 G35 Sedan with a non-revup and a 06 350Z with revup engine. And if they both have the MREV2 and spacer installed, they dyno identically.
Tony
I had no clue that Infiniti under rated the engine output on the 04 sedans.
Also very interesting that the 04 sedan and the 06 rev-up 350Z dyno the same with the MREV2 and spacer.
Old Dec 12, 2008 | 02:47 PM
  #63
blaccG35's Avatar
Originally Posted by G35papa
MREV is meant for the revup VQs only. DIY vid applys to 03-06 sedan and coupe.
yea but tony mention that if you have a non rev-up motor you should get the spacers first and the MREV is a option after you get the spacers
Old Dec 12, 2008 | 03:19 PM
  #64
Yv12345vY's Avatar
DO IT!
Old Dec 13, 2008 | 10:34 AM
  #65
PRMax's Avatar
Originally Posted by dmitriylm
I've actually seen it stated many times that MREV can indeed work with non revup VQ's.
I thought I read somewhere that there would be a problem closing the hood if you install the MREV with the 5/16 space on the sedans. Can someone verifiy if this is true.
Old Dec 13, 2008 | 11:25 AM
  #66
Hydrazine's Avatar
No, not at all. The MREV2 is the exact same height as the stock lower collector because it is a modified (non-revup) lower collector.
The combination fits perfectly. After installation it will look and fit like stock.
Old Dec 13, 2008 | 11:48 AM
  #67
G35Papa's Avatar
Tony...I've always read that the MREV2 only showed significant gains on the revup engine...can you please clear up if non-revup will show similar gains as well? I already know they will bolt up on both.
Thanks
Old Dec 13, 2008 | 12:25 PM
  #68
Texan1's Avatar
Q50 Red Sport 400 RWD
Finally bit the bullet and got the 5/16th plenum spacer from Motordyne. Now all thats left is Hotchkis sways along with a set of 19's and I think I'm done modding.
what about an HKS, sounds sooooo good with the cpe m.p.
Old Dec 13, 2008 | 01:33 PM
  #69
dmitriylm's Avatar
I've debated exhaust for a long time but am still not sure if I'm willing to go that route. I had a HKS HiPower setup on my 300ZX that sounded amazing, was incredibly loud and received a proportionate amount of police attention leading to many tickets (even though I had it checked by a state referee and with silencers installed it barely passed so I had paperwork to prove legality). I've wanted a more exotic sound but not sure if I'm willing to deal with any drone since in daily driving the car spends most of it's time below 3000rpm.
Old Dec 13, 2008 | 01:56 PM
  #70
Texan1's Avatar
Originally Posted by Seymore
I did it with a buddy that knew less than me.
No problems during or since. It took a couple of hours but I was pretty meticulous.
Originally Posted by Wannabe6MT
Took me the longest time, and some nasty words to get those bad boys off.
Editing, it can make you look GAY
could this be one of u^^
yes, I'm 12 yrs old
back on topic, thanks for the information definitely informative.......
the drone is minimal imo. But, you may not agree. The only time I feel it is much is occasionally when I have a stressful day and drive home with a pre-existing headache or say a cold/congestion aches. The good thing is it is relatively quiet at cruise and then sounds wicked azz good/loud at WOT along with some cool pops and burbling noises. The small amounts of drone imo are WELL worth the sweet serving of "Get acquainted with my tail lights and HKS exhaust spray" when passing someone.DOMO
Old Dec 14, 2008 | 02:48 PM
  #71
Hydrazine's Avatar
Thanks
Below is a comparison of Stock Vs Spacer Vs MREV2 Vs Spacer with MREV2. All of this testing was performed on a 2004 G35 Sedan with the non-revup engine.
Also see this link to an independent test on a NON-REVUP engine.
http://my350z.com/forum/showthread.p...ighlight=mrev2
Here is a link to independent testing on the REVUP engine
http://my350z.com/forum/intake-exhau...-included.html
Old Dec 15, 2008 | 12:44 PM
  #72
G35Papa's Avatar
Thank you for clearing that up Tony. Great info
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
saywat?
Sep 22, 2015 05:42 PM
bigmike
Sep 17, 2015 01:58 PM
Terry_G35
Sep 10, 2015 08:17 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
