installing coupe mid-pipe
Old Dec 11, 2008 | 05:19 PM
mcaron's Avatar
Ok heres the story, i have a 2004 g35 sedan, and ive got a 2003 coupe midpipe i want to put on. ive visited every local place including Nissan, so im going to infiniti tomarrow.
What id like to know it first, which 2 gaskets will i need, i was told that im going to need a flang gasket for the end that connects to the y pipe and a ring gasket that connects to the rear muffler.
Next, when im geting these parts i should go by the midpipe sizing because if im not mistaken the seadn midpipe is 2.25 while the coupe is 2.5?
I bught the flange gasket at nissan and its like a few very thin sheets of metal together and the gasket is curved slightly. Is this one of the right peices? Also on the coupe mid i got, i geuss he forgot to take off the old ring gasket, so ive been using this to try and find but but have no luck, it looks sort of like an oversized keychain haha. Fianly can i just use 4 bolts from my local hardware store instead of paying lots of $$$ at infiniti?
Sorry i dont know my terms or anything, im just really new to all of this lol
Thanks for your help
Old Dec 11, 2008 | 05:43 PM
mcaron's Avatar
here are some pics:
This is what i bought at the nissan dealer which goes between the y-pipe and mid-pipe right?
and this is what i found on the other end of the mid-pipe which connects to the muffler. Is this what im going to have to buy?
And is that all i need besides the new nuts and bolts?
Old Dec 11, 2008 | 06:34 PM
canucklehead's Avatar
can't see the pics, but the flange gasket you describe sounds correct. it's 3 or 4 thin sheets pressed together at either side. the crush (or ring) gasket is a circular piece of metal that is overlapped around its circumference to allow it to crush without binding. if you can't find a new crush gasket it won't kill you to re-use the old one, it's not the end of the world.
i re-used the nuts and bolts that were on the car. when i installed the HKS rear section i had to use "hardware store" stainless nuts & bolts. you'll be fine.
one more thing: soak the existing nuts & bolts with a lube or rust buster for a while before you remove them. mine were no problem but lots of guys have a hard time with ceased nuts/bolts.
Old Dec 11, 2008 | 06:45 PM
Hotdawwgman's Avatar
I was able to reuse all my hard ware... the mid-pipe just connecrs up no problem!
Old Dec 11, 2008 | 06:47 PM
mcaron's Avatar
ok so i geuss im on the right track haha makes me feel alot better.
and yeah i just read an old thread and everyone in it were having a reallyyy hard time getting the bolts off, but hopfully i can get it done with my friends help.
Old Dec 19, 2008 | 03:05 AM
KrazyZenki's Avatar
What is the point of installing the coupe midpipe on the sedan? I keep reading people installing them or that have them installed but not sure why.
Old Dec 19, 2008 | 07:58 AM
mcaron's Avatar
coupe mid-pipe has a much smaller resonator, so it just makes it sounds alot better, i used to listen to my music in the car, now i losten to my exhaust haha
you can get one used anywhere from 25-75?
but im just letting you know, make sure you have the right toold because all the rust is a PITA, took me almost 3 hours to install.
Old Dec 19, 2008 | 08:23 AM
KrazyZenki's Avatar
Its only neccessary on the 03-04 sedans right?
Old Dec 19, 2008 | 08:32 AM
mcaron's Avatar
i believe so, if you wanted if you have an 03/04 sedan you can put i think just about any coupe mid-pipe on, orrrr a 05/06 SEDAN mid-pipe on. Both have a similar sound with the sedan mid pipe being alittle "deeper"
Old Dec 19, 2008 | 12:06 PM
^ there are more coupe middys on the market than 05-06 sedan middys. i'd say spring for a coupe middy in good shape, any year.
in addition to improved exhaust note the coupe middy also shaves off about 30lbs, which is always a good thing...
Old Dec 19, 2008 | 10:24 PM
mcaron's Avatar
All true
Old Dec 20, 2008 | 12:27 AM
DaveB's Avatar
No point in getting new gaskets. The OEM ones don't wear out.
I've had both the coupe midpipe and the 05/06 sedan midpipe. The sedan midpipe sounds far better. It's deeper and has a more uniform sound because the resonator was designed to work with the muffler design of the sedan. Even better is the sedan midpipe doesn't drone and it fits like OEM with no modification needed of the heat shields. As for finding one, yeah it's harder but worth it if you can find one.
Old Jan 13, 2009 | 11:09 AM
jmueller's Avatar
Just installed the Coupe Midpipe.. I have to buy some gel like gasket maker, to seal the rear bolts / connection. I still have some rattle though, im pretty positive its from the drive shaft protection bar before the exhaust hanger.. Any ideas?
Old Jan 13, 2009 | 11:16 AM
mcaron's Avatar
yeah i have a little bit of rattle when the car is cold, but once its warm it usualy doesnt rattle
Old Mar 28, 2009 | 01:43 PM
jmueller's Avatar
i actually put some RTF orange (the gasket seal/maker stuff) on the bar, and it lowered the amount of rattle for a while. but its back, im just kinda used to it now i guess. but yeah the rattle goes away after about 10 seconds.
EnCr1pt3d
Jul 8, 2019 02:48 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
lemmy999
Jul 25, 2015 12:13 PM
Ashton35
Jul 22, 2015 09:19 PM
