should i remove the heatshield if i install HFC
Old Dec 14, 2008 | 09:49 PM
4drmadness's Avatar
hey guys i have read through some posts in which people said that their exhausts rattle. should i bend the heatshield before putting on hfc so i dont have a problem? does anyone have a picture of what a heatshield looks like cause i have no idea, and should i use a crow bar to bend it? thanks
Old Dec 15, 2008 | 06:30 AM
6MTFTW's Avatar
Personally, I would leave them there. Afterall, they're there for a reason. When you get under there and get the stock cats off, you'll see them.
-Jerome
Old Dec 15, 2008 | 04:50 PM
ttrank's Avatar
Grocery getter
Keep them.
Old Dec 15, 2008 | 05:44 PM
4drmadness's Avatar
but some hfc cause rattling because of the heatshield right?
Old Dec 15, 2008 | 11:48 PM
G35Papa's Avatar
Crawfords original design was know to hit the OEM heatshield...in the revised version, this wasnt a problem anymore.
Even if you install the hfc and then run into issues with the oem shield, you can remove the shields without having to remove the hfc or just get a large screwdrive to bend the shield a bit. It would hit towards the top of the shield, where it bends up. You'll see what I'm talking about once you get under and look.
So, keep them on
Old Dec 16, 2008 | 12:30 AM
4drmadness's Avatar
thanks, that really helped me.
Old Dec 16, 2008 | 08:56 PM
G35Papa's Avatar
No problem...good luck
Old Mar 18, 2010 | 12:27 PM
syshs's Avatar
So, keep them on
When did the revised version come out?
What are all the differences between the original version and the revised version?
The reason I ask is b/c... long story short, I have a pair of Crawford HFCs, and the driver side n passenger side from 2 different sources, and the placement of the inside "web" or "comb" or whatever you call that, is different.
On one, the "web" is deeper inside and at an angle, while the other is straight and much closer to the end opening.
Thanks!
Old Mar 18, 2010 | 12:32 PM
syshs's Avatar
On one, the "web" is deeper inside and at an angle...
While the other is straight and much closer to the end opening...
Old Mar 18, 2010 | 12:43 PM
G35Papa's Avatar
Um....sometime before 2008 I have no idea when the revised came out. I just remember buying the revised set. IIRC the revised version had more of a bend to it and cleared the OEM heat shield.
Try giving them a call.
http://www.crawfordzcar.com/html/high_flow_cats.html
Old Mar 18, 2010 | 12:45 PM
syshs's Avatar
^ i called them right now and they said the inside should look the same... crap!
i guess, the one thats deeper inside is melting and on the verge of blowing???
Old Mar 18, 2010 | 01:51 PM
G35Papa's Avatar
That sucks. See if they will sell you a single one.
Old Mar 18, 2010 | 02:16 PM
syshs's Avatar
^ g35papa, thats my guess, that the one thats deeper inside is going to bust, i might be totally wrong... what do you think?
WillisFL
Dec 29, 2016 08:56 AM
Mick_L
Aug 25, 2015 04:27 PM
mdzukunft
Drivetrain
Aug 25, 2015 10:28 AM
RA102223
Intake & Exhaust
Jul 25, 2015 01:03 PM
