Rev-Up airbox on a VQ35DE - special note
Old Nov 20, 2012 | 09:26 AM
  #406
socketz67's Avatar
Rick over at Perry Infiniti in SD always has a couple of these (lower portion that is different) listed in his Ebay store for $79.
OEM INFINITI FACTORY REV-UP INTAKE AIRBOX WITH VELOCITY STACK G35 350Z NEW
Old Nov 20, 2012 | 05:10 PM
  #407
That's G's Avatar
So does everythingG35.com. That's where I bought mine for any future readers of this thread.
Old Nov 20, 2012 | 05:26 PM
  #408
Jeff92se's Avatar
Red Card Crew
Originally Posted by Carrera57
How easy was it to swap the velocity stack from the 350z box to the stock G box? Did you just drill out the rivets in both and just use the 4 bolts or did you re-rivet it to the G box? I'm buying an '06 350Z airbox today for $40 and I wanted to know how much work it will be.
I drilled out both stacks and used the 4 bolts. Then just used two machine screws to plug up the rivot holes You can re-rivot or just use silicone sealer or something.
IMHO with so many used Zs around, it's not worth the $80 to buy a new lower.
Old Nov 22, 2012 | 02:12 PM
  #409
AZWoodG35S's Avatar
This is what i did plus high temp black sealant to make a little more stealth.
Old Feb 25, 2013 | 01:26 PM
  #410
MIKERNM1990's Avatar
I know it's old. But just bump! So anyone dyno for rev up air box? I've heard about it can make 2-3 hp or 3-5 hp. Which is part of power band? low end or mid range or top end?
Thanks
Mike
Old Feb 25, 2013 | 01:27 PM
  #411
Jeff92se's Avatar
Red Card Crew
No one is going to dyno this thing. 2-3 hp is well within dyno error. It's more for some low end pickup vs total hp
Old Feb 25, 2013 | 02:11 PM
  #412
RicoG35x's Avatar
not so much an HP boost mod.. more so a drivability mod.. it tends to smooth out the drivability of the car... not so much give you an actual HP increase... ya know?
Old Feb 25, 2013 | 08:50 PM
  #413
MaDMaXX's Avatar
Something like that, my tuner wanted it on before tuning as it makes the readings more reliable/flow of air over the meter smoother etc.
Old Feb 26, 2013 | 01:18 AM
  #414
Thank guys! Maybe I've noob question. You said that rev up airbox has notice difference low end only. Is it has a little improve fuel economy? Or maybe I'm wrong?
EDIT: I don't care about top end. I always shift gear less than 3 or 4 rpm because I'm eco modder, not performance. I think you have noticed difference rev up air box with other mods or not?
Old Feb 26, 2013 | 08:45 PM
  #415
RodzMax2002's Avatar
I've had this mod for about 3 years now and I would say the same..1+with RicoG35X,It makes the rpm band alot smoother and when the weather is a little cooler out the car seems more responsive.I would say the fuel economy has stayed the same for me.
Old Feb 27, 2013 | 09:55 AM
  #416
Peoria35sedan's Avatar
Eco modder, that's a new one for me. I'm guessing the G35 is not your typical eco modder platform.
In theory this would increase economy since it cleans up the airflow over the maf sensor allowing for more acurate readings.
Old Feb 27, 2013 | 10:17 AM
  #417
RicoG35x's Avatar
Thing is bro... any minimal gains in MPG's.. if ANY, will probably get swallowed up by the change in drivability smoothness... (right-foot syndrome)
Old Feb 27, 2013 | 09:11 PM
  #418
MaDMaXX's Avatar
Yeah, what Rico said
It's probably cheaper to get the mod version i got unless you can find a cheap revised airbox somewhere.
Old Jun 20, 2015 | 10:23 PM
  #419
SIKKI's Avatar
Just in case anyone is wondering, the upgraded half of the box is Nissan part #16526-AC700.
Old Aug 31, 2016 | 07:56 PM
  #420
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
Might poke around the wrecking yards for an airbox.
