Test pipes and oil consumption
Old Jan 31, 2009 | 06:00 PM
RaginRaj11's Avatar
Originally Posted by HomieG35
You are missing something. I don't believe there is anyway that even a full exhaust system could cause the engine to start eating oil.
The best way to prove it is to say,
-No oil consumption
-Installed test pipes
-Had oil consumption
-Removed test pipes
-No oil consumption
-Install test pipes again
-See if you have oil consumption
Only way I'm gonna buy it. And then we have some serious investigating to do as to way it's happening... but I think something else is going on.
It may be that your car has an issue. With test pipes and exhaust you liked the sound, took it to redline more often, and the problem made itself known. You took off the test pipes, were scared about consuming oil and never floored the car anymore, and the consumption issue is subdued, until the next time you start redline it again.
Im currently having an oil consumption test done so if the dealer says everything is ok, then i will go ahead and re-install the test pipes to see if the problem occurs again.
Eomfd
Aug 29, 2015 12:42 AM
nickmcc123
Aug 20, 2015 03:10 PM
ghost_g35
Aug 7, 2015 10:31 AM
lemmy999
Jul 25, 2015 12:13 PM
