injen exhuast w/x pipe
Old Feb 17, 2009 | 01:11 PM
(Stealth Inc.)'s Avatar
would it be possible to add in x-pipe to the injen exhaust, by removing the h and replacing it with the x it seems like it might be limited room. has anybody done this?
Old Feb 17, 2009 | 02:12 PM
Jeff92se's Avatar
Red Card Crew
I believe it's been done on the Z more than a few times. It also depends on which X pipe you use. A straight X pipe is pretty small while a resonated X pipe (looks like a 2in/2out muffler but with a true x pipe inside) are usually longer. But you might gain some room if you go with the resonated X and dump the Injen resonators?
The only problem I see is that the H pipe is welded in right at the bends of the downpipes. But any shop should be able to handle it.
Old Jan 17, 2011 | 02:46 PM
doeboy's Avatar
did you ever try doing this?
Old Jan 18, 2011 | 12:21 AM
yeah i tryed it but it didn't work too well their was still drone issues so, I scraped it and bought a fast intentions exhaust it already has a resonated xpipe built into it no drone either well worth the money.
Old Jan 18, 2011 | 02:28 AM
doeboy's Avatar
Was the X-Pipe a Magnaflow #11385? I just installed my exhaust yesterday and it has a lot of drone but it doesn't bother me that much. I do have a lil rasp on mine since I do have test pipes added in. I thought I might try to make it a lil quieter and maybe eliminate the lil rasp that I have. The rasp dropped by 50% since the install of the new exhaust.
Old Jan 18, 2011 | 02:45 AM
now that i remember it was non-resonated xpipe just before the the resonators on the injen, if your trying to add a resonated xpipe you would have to cut out the h-pipe and resonators on the injen and replace with magnaflows resonated xpipe.
kinda like what dcityjatt did to his xo2 different exhaust same principal.
https://g35driver.com/forums/intake-...est-pipes.html
Old Jan 18, 2011 | 03:49 AM
doeboy's Avatar
That's what I was planning on doing. The diamater of the pipe is 60mm which is 2.38". Would I need to get a 2.5" or 2.25" X-Pipe muffler? If that doesn't work completely maybe another resonator down the pipe but from what I have been reading and researching is that that X-pipe is a miracle worker lol. So maybe hopefully in a month I will have it on and will post sound clips of before and after. How much should I be looking at to replace all of that?
Old Jan 18, 2011 | 04:12 AM
try the 11386* it's 2.5 vs. the 2.5 of the 11385* as far as price here is a example http://www.ourdealsrock.net/256-11386.aspx but labor and all that i wouldn't know. good luck bro post vids when complete.
Old Jan 28, 2011 | 07:34 PM
doeboy's Avatar
Well I just ordered it and hopefully should be here and installed by next sunday
Old Feb 7, 2011 | 07:42 PM
doeboy's Avatar
I started a new thread with my sound clips
Old Feb 7, 2011 | 08:58 PM
link? hope it worked out.
Old Feb 7, 2011 | 10:05 PM
doeboy's Avatar
Link is right here
https://g35driver.com/forums/intake-...und-clips.html
Video Share
Jan 31, 2017 04:00 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
9tray turbo
Sep 29, 2015 10:22 PM
