how can you make the jwt popcharger more effective
Old Feb 22, 2009 | 10:07 PM
4drmadness's Avatar
according to stillens website, they are still selling it together
Originally Posted by OCG35
I believe Stillen finally started selling just the heat shield alone... it took them a while - I was asking why they didn’t a few years ago, and since them I've heard they are.
You've always been able to buy the pop charger separately (without heat shield).
So yes, I’m pretty sure you can do the Stillen heat shield pop charger combo with out buying both full kits.
Old Feb 22, 2009 | 10:41 PM
OCG35's Avatar
call them... I'm almost positive (relatively recently) ppl have bought the heat shield only... maybe it was a temporary thing?... Give 'em call.
Old Feb 22, 2009 | 11:24 PM
4drmadness's Avatar
Tollbothwilley called them a couple days ago, and they said that they were selling the intake together. Ill still give them a call tmrw to make sure
Old Feb 22, 2009 | 11:35 PM
OCG35's Avatar
or put a WTB ad in the classifieds... a lot of guys are jumping on the OEM air box band wagon and might be selling their Stillen heat shield.
Old Feb 22, 2009 | 11:43 PM
SDGenius's Avatar
or you could just put the R2C filter on ur JWT setup...
Old Feb 22, 2009 | 11:46 PM
SDGenius's Avatar
if ur really worried about intake temps, the samco Z-tube may help. the iso-thermal from MD does wonders too.
Old Feb 23, 2009 | 12:00 AM
SDGenius's Avatar
i've also thought about adding the ARC cooling fins to my intake pipe but i don't wanna block off my coolent valve.
Old Feb 23, 2009 | 12:50 AM
OCG35's Avatar
the Samco tube wont fit (without cutting) with the tbs he's using... I had one last week and had to send it back... in fact anything other than OEM z-tube is a pita with the tbs - I finally got a cf z-tube and having issues with it as well (need to find specific size couplers, I have some ideas).
Anyway - anyone looking for a Samco tube for decent price contact Adam at Z-1 (he's a vendor on 350z), I just sent back the only one he had. And anyone looking for CF z-tube, I’ll let you know were to get it if I cant get it to work (I ended up with the only one around, but might need to return it too).
Old Mar 4, 2009 | 06:10 PM
The Stimulation's Avatar
I created a similar thread to this. I'll be modifying the OEM box by cutting it most likely and doing some fiberglassing.
Old Mar 4, 2009 | 06:30 PM
Jeff92se's Avatar
Red Card Crew
Why anyone would want to swap the JWT filter into the Stillen is beyond me. Don't they both use oiled cotten media?
Anyway, I saw the pic of the R2c filter on the Stillen. From what I see, I don't see why the power duct still wouldn't fit. The two mounting holes are still there. I don't see where any cut part of the Stillen box would affect the mounting of the power duct?
Old Mar 4, 2009 | 06:36 PM
I'm assuming because of looks? I personally choice the JWT because it's what I was recommended when I was a noob looking for a first mod. I kinda don't like Stillen either, but I do see why people would want to swap the heat shield out from the JWT setup. I'm surprised JWT hasn't done anything about it. They would sell like hotcakes if they did.
Old Mar 4, 2009 | 06:44 PM
redlude97's Avatar
The only reason i can see to do the swap is because the JWT has an inverted cone on the top as opposed to the solid top on the stillen(K&N) which could potentially decrease the pressure drop across the filter and thus allow more airflow if that was a restriction.
Jeff92se's Avatar
Red Card Crew
Originally Posted by TURBOTOM
I put my pop-charger filter on with my stillen airbox. IMO that is the best combo for an intake on this car. Its too bad stillen does not offer just the heatsheild from there intake.
Looks like he just took the filter media itself and put it onto his stillen setup. Why? And why would it be better than what stillen already has? Both use the same type of oiled cotton and both use the same velocity stack mounting base. If he had a stillen, he already has a filter for it. The JWT filter media might be a tad longer but that's it. Nothing worth swapping for. I'd consider using a longer filter IF that was the only way to get a superior filtering/flowing unit in there.
Old Mar 4, 2009 | 06:48 PM
Jeff92se's Avatar
Red Card Crew
I suppose but IMHO, it comes down to filter area. If it's already large enough, I don't see how a slightly larger one would help. Plus if you make the filter case too long, it will start to get really close to other parts of in the engine bay.
Old Mar 4, 2009 | 07:15 PM
  #30
OCG35's Avatar
Jeff, he's saying the Stillen cone is capped off at the nose - the JWT is concaved - theoretically/possibly better airflow.
I doubt there would be notable difference, but I need an alternate filter during cleaning - so one of these days I plan to get JWT to swap back and forth with...
