Header Install - problem - need help
Old Mar 19, 2009 | 01:51 AM
Tollboothwilley's Avatar
Installed my headers... very large pain in the ****. So...I get the car put back together and I am getting a leak on the passenger side. UGH!! I dunno what the leak is from, maybe the gasket got pinched or something.
Lets say I really don't want to take the car apart again, but I will have no choice...
Problem is this: I'm getting an SES light. Can this be cause solely by manifold leak? I'm wondering if it is linked to pre-cat O2 sensors. I changed out the O2 sensors post-cat while putting it back together.
Would love to have a Tech shed some insight...
Old Mar 19, 2009 | 11:23 AM
xXHotelCrazyXx's Avatar
What kind of headers did you install. Did you torque them in the proper sequence? Like this
(Header nuts)1 being the top middle nut, 2 being bottom middle and so on...
613
425
Old Mar 19, 2009 | 12:27 PM
Yes, i torque them in the proper sequence. I also wen't back through to retorque them in the same sequence afterward, to make sure they were all tight.
Old Mar 19, 2009 | 12:30 PM
So can you hear this leak or are you assuming its a leak just because of the SES light?
Old Mar 19, 2009 | 12:35 PM
Honestly the best way ive been able to find leaks would be to disconnect a vacuum hose and stick the hose into a bottle (like a straw in a coke bottle) of marvel mystery oil or sea foam. You will almost always see the smoke coming out of the leak.
Old Mar 19, 2009 | 12:36 PM
IrockAG35's Avatar
Ohio G Club moderator
wow,heard headers were a pain,should have gotten it done..GL..post a diy if you get time
Old Mar 19, 2009 | 12:42 PM
Headers are a HUGE pain. I wanted to do it myself.
I had a tech tell me to spray it with water.
Can header leaks cause a CEL??
Old Mar 19, 2009 | 12:43 PM
BTW, I can hear the leak
Old Mar 19, 2009 | 12:53 PM
DaveB's Avatar
Yes, a header leak can cause an SES.
Which gaskets did you use. OEM is the ONLY way to go. It is quite possible that the header flange was slightly warped from welding. There's a reason why OEM uses heavy high stainless steel for exhaust manifolds. You should always check the trueness of a header flange prior to install.
Old Mar 19, 2009 | 01:02 PM
I think it was the gasket. I didnt use the OEM, i used the gasket that came with it. Its possible that it pinched or something... Not sure.
Old Mar 19, 2009 | 01:19 PM
Jeff92se's Avatar
Red Card Crew
You should check WHICH CEL code is tripped. It's probably an 02 sensor code
Old Mar 19, 2009 | 02:01 PM
Dont spray it with water, it can cause the header to crack due to the shock of colder water. Do what i mentioned above!
Old Mar 19, 2009 | 05:21 PM
The leak was caused by a manifold stud not all the way in. I got it tight now.
Old Mar 19, 2009 | 08:12 PM
Nice
chinee
Jun 10, 2024 07:48 PM
CrazyLogic219
Aug 13, 2015 06:40 PM
saskicker32
Aug 11, 2015 02:12 PM
yosip1115
Engine - Exhaust
Jul 22, 2015 01:47 PM
attarday
Jul 15, 2015 04:03 PM
