Z tube question
Old Mar 24, 2009 | 11:08 PM
4DGS's Avatar
Z tube question
Can't find any info on it, when installing it does it have a place for the intake sensor? or do you have to modify it to work?
I found a used one for $60 Canadian, does that seem like too much? To me it does since it's just a pipe....right?
Old Mar 24, 2009 | 11:11 PM
GEE35FX's Avatar
That price is pretty good.
Your sensor goes ahead of it. I will look up a couple pics for you.
Old Mar 24, 2009 | 11:17 PM
BuckeyeInMI's Avatar
By "intake sensor" do you mean the Mass Airflow Sensor? If so, it's not part of the Z-Tube. It's part of the housing that comes out of the back of the airbox. $60 Canadian is what, about $45-$48 US? That's a pretty good price. Used doesn't really matter, it's just a piece of sturdy plastic.
And the stock tube is also "just a pipe", but it has baffles in it to reduce air intake noise. It does a good job of it, but that also restricts the intake a little bit. The Z-Tube doesn't have the baffles, so you get better airflow, which means a little boost in both power and intake sound. But most people, especially here, think it's a nice new intake sound.
Get it. It's a pretty standard mod.
Old Mar 24, 2009 | 11:23 PM
GEE35FX's Avatar
Here are a few pics
Pic 1 Z-Tube and OEM G-Tube
Pic 2 and 3- You can see the air flow sensor on the left side before the Z-Tube
Attached Thumbnails Z tube question-z-tube-g-tube.jpg   Z tube question-z-tube-2.jpg   Z tube question-z-tube-3.jpg
Old Mar 24, 2009 | 11:27 PM
4DGS's Avatar
Yea I've seen both the intake just wasn't fully sure about the sensors.
For the filter portion what would be the best bet (that doesn't include a pipe) I have a K&N from my old car and could just drop that in, but it wouldn't have a heat sheild and would be sucking hot air.
Does this have the tube or is it just the filter/heat shield? http://www.g35parts.com/9083/osc/pro...5bc48c12c75449
Thanks for the quick responses.
Old Mar 24, 2009 | 11:44 PM
The stock airbox is pretty efficient, and isn't really sucking hot air. Lots of people have the Z-Tube/K&N combo and it works pretty much as well as anything else short of FI. You'd be better off saving the money on the JWT and spending it on a plenum spacer. The spacer not only "unrestricts" the plenum, it has a lower gasket that really helps reduce any heat soak. My plenum is only slightly warmer than the ambient temps after driving it. The gasket does a nice job.
Old Mar 24, 2009 | 11:47 PM
HLMAX's Avatar
The G stock intake is well designed and very open. Also it take air for outside the hood. I don't see much benefit from an aftermarket intake. Pop in a K&N and save the bucks for other mods.
4DGS's Avatar
Yea I think I am just going to clean my K&N and oil it up then put it in the stock air box.
Plenum and grounding wires are my next buy. Thanks guys!
Old Mar 25, 2009 | 12:03 AM
PM the guys at Riverside Infiniti (Tony or Rick). They'll hook you up with a good price on an MD spacer. I would recommend getting the Copper ISO upgrade since you live in snow country (like me). I got mine shipped for $240US (spacer and ISO upgrade). Your shipping will be a little higher.
And look around for a good grouding kit, 8-10 wires, not some over-priced 5 wire setup. I got mine from a regular over at NICOClub.com named SentientByDesign. Really good quality, 4 guage wire, Copper connectors, excellent installation instructions.
http://forums.nicoclub.com/zerothread?id=345479&page=1
And you need to post some pics of your car. Emerald Mist is awesome.
Where in Ont.? A good friend of mine is from Chatham, and she's got sibs in London and Barrie.
Old Mar 25, 2009 | 12:15 AM
4DGS's Avatar
I am not sure I am going to go with the iso version, I just want the quick and easy 5/16" everythingg35.com has the spacer for 199 plus shipping and they also have a few other things I need at the moment. likes clear corners and what ever else I might want ahha, But I will keep riverside in mind.
I think I am going to go with GroundingGear for the 10 wire kit, he's a Canadian guy and I'm down to support his cause
I pick the car up tomorrow at 3, I don't even own the car and I am already filling a shopping cart. I'll have the stock photos up tomorrow, but it should be lowered by the end of next week and have the Z-tube and what not done as well.
I'm from Cambridge(5 Minutes from Kitchener) not to far from London or Chatham.
Oh by the way, I am still unsure if I am going to drive my G in the winter. I hate RWD with snow, I might just pick up an old school pathfinder or QX4. Probably mod the **** outta that too!
Old Mar 25, 2009 | 12:24 AM
If you're not driving it in the winter, then skip the ISO. You can always add it later. And Grouding Gear makes good stuff, plus you gotta support your fellow Leafer. Everything G35 is good to work with too, I got my Z-Tube from them. Riverside just had a better deal at the time. Enjoy the car, and good luck with your installs.
And I'm sorry, but not having the vehicle is no excuse for not posting pics!
(like I should talk, all I have are crappy pics from the dealership)
Old Mar 25, 2009 | 07:48 AM
STCLAIRWEST's Avatar
I love RWD in the winter!
Old Mar 25, 2009 | 02:21 PM
ttrank's Avatar
Grocery getter
I love RWD all the time.
Old Mar 25, 2009 | 02:29 PM
wonlife's Avatar
Z-toob on an FX35?
Anyone know if a Z Tube can be fitted to a 2007 FX35?
Th611
Oct 27, 2015 03:48 PM
yosip1115
Engine - Intake/Fuel
Oct 16, 2015 11:37 PM
w4kj4k
Oct 7, 2015 01:26 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
