Stillen Exhaust making pop sounds?
Old Jul 1, 2004 | 12:09 AM
Gotchaa's Avatar
I don't know how to really explain it, but my Stillen exhaust has been making popping sounds after reving, and when driving and shifiting in 1st gear, and letting the gas go. I've had the exhaust for about 4 months and this just recently started happening on my 6mt sedan...is this normal? Or is something wrong with the fitting? Exhaust leak?
Old Jul 1, 2004 | 06:05 AM
StVincent's Avatar
Re: Stillen Exhaust making pop sounds?
sounds like a backfire.. i had same thing happened on my previous ride when i had no cat.. not too sure if it's a good or bad thing.. can someone elaborate?
04 G35C 5AT, Black/Graphite, Premium, Aero, Performance OEMfrontlip,splashguards,alumpedals
-JWT pop charger
-Z tube
-TEIN s-tech springs
-Greddy SP2 exhaust
Old Jul 1, 2004 | 09:45 AM
quikrocket's Avatar
Gotchaa,
Mine does that a little bit too, but it sounds more like a "burble." I think that's going to happen on an exhaust that is less restrictive than the OEM pipes. I'm quite sure its normal...
Q
2003.5 Silver Sedan
6 Speed
6 Wire HGK
Z-Tube/Pop Charger
Stillen Cat-Back Exhaust
Old Jul 1, 2004 | 11:29 PM
karlhungus's Avatar
Its typically caused by an over-rich condition. If its more than a burble and its something new, I would take it in for a A/F/Timing diagnostic. I've had the Stillen exhaust for 6 months and never a pop or backfire.
Old Jul 5, 2004 | 01:28 PM
Gotchaa's Avatar
perhaps I should try an ecu reset first?
Old Jul 6, 2004 | 06:25 PM
karlhungus's Avatar
You could try a reset, but unless you had a code or something, I doubt that would help. The ECU should have adjusted to the Stillen long ago.
Old Jul 21, 2004 | 10:46 AM
SoCalTed's Avatar
I've got Stsillen Dual (sedan) and Crawford hi-flo cats.
I've noticed a "burbling" sound on the exhaust at idle. Not unike my old 390 V8, pleasant - but disconcerting to those who are used to "quieter" exhausts.
When I took my sedan down to TechnoSquare, Tadashi played with the car while doing the ECU. He stood behind t he car and scratched his head... he had not heard any other G doing this. It didn't bother him too much... but if it was because the fuel was too rich, Tadashi could have fixed that then and there.
He actually suggested that I change out my spark plugs, going one step colder.
-Ted
'03.5 Sedan 5a: BS/G, Prem, Aero/Body, Sport, Nav
Click for MODS or Vote at Online Showoff
Old Sep 25, 2004 | 09:40 PM
Gotchaa's Avatar
I guess it is a burbling sound. I've been thinking about the technosquare, I've got a 6MT and wondering if the ECU programming would maximize the exhausts performance. Not sure if AT and MT are the same, but I've got the the z-tube and stillen cai as well, and wondering if it's worth the investment?
SoCalTed Did you end up changing your plugs?
Old Sep 25, 2004 | 11:12 PM
lowrider's Avatar
This sound is normal with any engine. When you rev up an engine, and then back off, there is fuel coming into the exhaust that has not yet burned. It ignites, and that's the sound you hear. You don't hear it with stock exhaust systems because they are tuned to hid that sound. Stand behind a Harly Davidson (mine for instance) with a modified exhaust. Most Harleys have a modified exhaust, and you'll hear what I mean. Personally, I like that sound. But, it's entirely normal and nothing to worry about.
BTW, I have a TSU ECU, and this did nothing to alter the pop-pop sound. Nor, did I expect it to.
Lou
TWASkyliner
Feb 8, 2020 08:00 PM
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
derres
Aug 28, 2015 03:27 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
