Sedan Mid-Pipe Resonator removed
Old Apr 9, 2009 | 03:38 AM
BRice63's Avatar
so i'm pretty new to the forums and i don't post much so i figured i'd put this up
i just had a performance muffler shop remove the mid resonator and run an new S-bend in there and so its all stock exhaust except for a missing resonator
it shaves off a good 40lbs and added a very sporty sound with hardly any effect to the cruising volume
here is a pic of the resonator
and a video with the exhaust sound
i'm planning on getting headers, aftermarket cats, and a new (bigger) Y-pipe built with possibly a cutout
idk what to do with the muffler i'm still thinking about that
comments and suggestions (good or bad) are Very welcome
Old Apr 9, 2009 | 10:26 AM
g35freak86's Avatar
wow, that sounds reallly good man. Great work
Old Apr 9, 2009 | 10:29 AM
DieselX's Avatar
Sounds good now. Start adding those headers and hfcs and the sound will get loud and raspy. I went through it.. and then went back.
Old Apr 9, 2009 | 06:47 PM
fluxcapacitor's Avatar
how much did it cost u to do that
Old Apr 9, 2009 | 07:36 PM
10nara's Avatar
I tried that too, and it was kinda too loud for me, so I welded 350z resonator. Basically a coupe mid-pipe. The noise from no resinator kinda reminded me of stromung mufflers back in min 90's.
Old Apr 9, 2009 | 08:30 PM
BRice63's Avatar
just 50 bucks
all it is is an S pipe welded in to replace it
2.5"
its kind of loud around 2k rpm but it still has its sophisticated sound and not the ricer sound that those fart cans give you
sounds kinda v8'ish imo
Old Apr 9, 2009 | 09:15 PM
Bestswat's Avatar
damnn that sounds sickkk, i should have just done that instead. sounds like it would drone alot from the sound of the muffler at idle. any pics of midpipe with the s bend?
Old Apr 9, 2009 | 11:45 PM
UR2EZ's Avatar
can we get a pic of what it looks like under the car?
i'm wondering what you mean by s-pipe
Old Apr 10, 2009 | 03:51 AM
BRice63's Avatar
well its just a pipe replacing the resonator
and the pipe is at a slight S bend so it lines up correctly without sharp bends
here is a bad picture for you :P
you can see the fresh pipe is where its replaced
Old Apr 10, 2009 | 04:08 AM
S 854's Avatar
Very interesting. Did you notice if this mod produced more drone for you? Are you a 03-04 or a 05-06 sedan?
EDIT - looks like a 03-04 resonator in your pic.
Old Apr 10, 2009 | 04:28 AM
BRice63's Avatar
yeah 03
and i'd say it does produce some drone but its worth it for when i give it more than half throttle
and the idle is just SEXY
Old Apr 10, 2009 | 08:32 AM
Blue Dream's Avatar
I drove ttrank's car solo
Any noticeable improvement in power?
Old Apr 10, 2009 | 01:44 PM
is the drone unbarable?
Old Apr 10, 2009 | 03:03 PM
racefan318's Avatar
I see that the front is flanged into the y pipe, but how is the rear done? just a collar joining the 2 pipes or welded up tight?
__________________________________________________ _______________
Just listened to the clip... sounds great! Do you still ahve that old resonator layin around? and could maybe take some inlet to outlet measurements of it???
Old Apr 10, 2009 | 03:15 PM
BRice63's Avatar
i didn't do it for power just a better noise
but i'd assume it would gain like 2-5 whp because it frees up some back pressure
no its completely bearable because its only when i'm accelerating slowly and when i'm just maintaining a speed there is no drone
yeah its just chopped out and a pipe put in so the whole mid section has the same flanges as the car would stock from the back of the y pipe to the muff
and yeah i still have the resonator shown in the pick
the inlet (the wider side of the resonator box is the in side) is 2.5" and the outlet is 2"
interested buyer?
