Must a high flowing exhaust = RASP?
Old Apr 29, 2009 | 02:49 PM
GT-ER's Avatar
My car has headers with 2.25" collectors, 2.25" test pipes, 2.25" to 2.5" Y-Pipe and a mandrel bent 2.5" exhaust with a 2.5" straight through magnaflow muffler where the stock midpipe went and a 3" magnaflow straight through race muffler at the end.
The car feels great but I'm, really not happy with the rasp. The sound level is perfect for me but I would like to remove the rasp without affecting flow...is this possible?
Old Apr 29, 2009 | 02:55 PM
elayman's Avatar
If your exhaust is dual at any part (although you have a y-pipe so I don't think so) you can try and weld a support piece between the two pipes to prevent some vibration, or you could add a resonator?
Old Apr 29, 2009 | 03:46 PM
tiguy99's Avatar
Sounds custom....your muffler shop couldn't figure this out?
Old Apr 29, 2009 | 05:46 PM
str8dum1's Avatar
which model race muffler. without knowing which atcual sized parts were used, its hard to make a suggestion
Old Apr 29, 2009 | 06:30 PM
GT-ER's Avatar
I didn't do it in a muffler shop. I had a friend help me weld up the exhaust. I came out great and was tig welded but the sound isn't what I expected. It has way too much rasp.
This is the mid muffler I'm using:
http://www.magnaflow.com/02product/s...e=main&id=7968
And this is the rear muffler:
http://www.magnaflow.com/02product/s...e=main&id=8181
I had this same exhaust ( minus the mid muffler ) with the stock manifolds and stock cats and it sounded great. I installed headers and test pipes and the sound was mind boggling loud so I added the mid muffler. Sound levels are great now but it has a lot of rasp.
I've read a lot of people having the same problem and I'm just wondering if the only solution is to add cats again.
Old Apr 29, 2009 | 06:32 PM
Jeff92se's Avatar
Red Card Crew
People are using resonated X pipes to rid themselves of rasp on their duals. Not sure how you are going to handle this with your single.
Resonated Test pipes might be in order.
Old Apr 29, 2009 | 06:33 PM
DaveB's Avatar
Go back to the stock catback. You'll be much happier. With everything you'll need to do to kill noise and rasp, you're really going to choke the exhaust. Consider adding some resonated exhaust tips. They will actually help clean up the rasp.
Old Apr 29, 2009 | 06:37 PM
Jeff92se's Avatar
Red Card Crew
Dave. If this guy has headers, I think he's beyond the stock cat back IMHO. But that race muffler isn't doing him any favors.
Question is is the rasp coming from the front or back?
Old Apr 29, 2009 | 06:41 PM
GT-ER's Avatar
lol...correct...I live with the rasp before I go back to stock.
What do you mean by your question though?
Old Apr 29, 2009 | 07:01 PM
Jeff92se's Avatar
Red Card Crew
resonated test pipes might work. If not, you might be limited to hi flow cats. IMHO, there's not much hp diff inbetween test pipes and hi flow cats anyway
Old Apr 29, 2009 | 07:06 PM
GT-ER's Avatar
How about when supercharging? I plan on supercharging my car and if there is a decent amount of power lost by HFC then I'll live with the rasp. Resonatied test pipes don't sound like a bad idea though.
Old Apr 30, 2009 | 01:18 PM
DaveB's Avatar
You really haven't gained anything with your catback. The resonator and muffler really aren't that restrictive to begin with. If you want to tone down the rasp and volume, the stock catback is the way to go without compromising much power at all. A lot of your rasp is coming from that muffler, no resonator, and those TPs. They're all doing thier fair share. Go after the parts that don't effect power much at all, the catback.
Consider the HR y-pipe or MD XYZ pipe with the resonator as well.
Old Apr 30, 2009 | 03:45 PM
rcdash's Avatar
I think MD is coming out with something new for test pipes that does a great job of eliminating rasp. PM Hydrazine.
Old Apr 30, 2009 | 03:59 PM
GT-ER's Avatar
Well, after driving the car some more a lot of the rasp has gone away. Do mufflers "break in"? Seams to sound much better now.
I'll look into those MD test pipes.
magnetism80
Feb 1, 2019 10:00 AM
lamessi1018
Engine - Exhaust
Oct 20, 2015 04:24 AM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
TrillO.G.35
Sep 5, 2015 02:06 AM
erich2780
Sep 3, 2015 03:23 PM
