You know the side-tube that connect to the air box
Old Mar 27, 2003 | 10:04 PM
99atlantic's Avatar
You know on the air box to the left side there's that really long piece of tubing(that's held on by 2 push-fasterners)
Do you think you'd gain anything by removing it? I can see more airflow, but would it be hot engine air? What about like opening up the openings more (i.e. on the front of it where those 2 little slits are, to take a saw and cut bigger openings?
www.ironpumping.com
^^Bodybuilding Made Simple
Old Mar 27, 2003 | 10:56 PM
Marcel's Avatar
Re: You know the side-tube that connect to the air box
No you wont gain anything, you would see some loss of power though. You are talking about one of the airducts that actually sucks in air to the engine.
Marcel
G35C 6 MT
Volk GTC 19'x8.5' front; 19'x9.5' rear
Dunlop Sport 9000 245/35/19 front; 275/35/19 rear
Old Mar 28, 2003 | 11:37 AM
OvaYahead's Avatar
Are you talking about the vacuum hose next to the throttle body? I think that goes to the valve cover. On other cars you can fallow it back and put a breather on the valve cover instead of a vacuum hose connected to the intake pipe.
That tubing acts like a return passage. this helps the movement of the air. As the intake sucks in, some air is blown back out through this hole on the valve cover. If you put a breather on it, it helps the airflow a little bit.
BS G35C 6spd navi/aero/prem
Old Mar 28, 2003 | 04:23 PM
dspisak's Avatar
What I want to know is what is the plastic box in the intake tract between the air filter and the throttle body? The sedan and coupe have it, the 350Z does not have it. What does it do? Can it be replaced with the 350Z intake duct? The box looks as if it would be an air flow restriction.
<font color=blue>Dan</font color=blue>
Old Mar 28, 2003 | 06:39 PM
OvaYahead's Avatar
it's just a resonator. It's hallow and just bounces air and sound around in it. The whole stock intake system is full of little pockets like this.
Old Mar 29, 2003 | 01:26 AM
Marcel's Avatar
Ova the only resonator in the intake is the lil piece dangling below. Im pretty sure hes talking about the inlet that is right in the center above the grill.
Marcel
G35C 6 MT
Old Mar 29, 2003 | 05:15 AM
OvaYahead's Avatar
nope he's talking about this little box right before the Mas Air Sensor. It's flat on top and kind of a rectangle shape. Yuichi was trying to figure out what it was too. I looked inside and put my hand in there. It's just another piece to baffle sound. "resonator" can be anything that bounces sound around. A glass pack can be used for a resonator. An exhaust system or intake system can have multiple resonators.
Old Mar 29, 2003 | 10:57 AM
dspisak's Avatar
That is the correct component. I do not know what will be the benefit of a resonator in the intake tract. I think it is more than a resonator. There is at last one hose attached to it. Also, if there is a baffle inside, will that not restrict air flow?
Why is it not on the 350Z?
Old Mar 29, 2003 | 09:51 PM
Marcel's Avatar
according to the service manual the flat front part infront is an inlet not a resonator(its purpose - just more air i guess). the little piece dangaling down is a resonator.
Marcel
G35C 6 MT
Old Mar 30, 2003 | 03:26 AM
OvaYahead's Avatar
my bad i forgot the hose was connected to it.
Marcel did you see where that hose leads to in the manual? If it leads to the valve cover then it's just a little section for the air to just recycle back into the intake.
Old Mar 30, 2003 | 02:18 PM
Marcel's Avatar
If you are refering to the hose im thinking of then it goes to the LH rocker cover.
Marcel
G35C 6 MT
Old Mar 13, 2011 | 03:54 AM
dukehotty's Avatar
You should just get a Z tube.
Old Mar 13, 2011 | 06:37 AM
jookyshank's Avatar
I haz hugz to givez
Awwww no 2002...
Old Mar 13, 2011 | 12:18 PM
OCG35's Avatar
this wins for most useless thread bump ever.
Old Mar 13, 2011 | 03:01 PM
dukehotty's Avatar
I think this bump will take the cake....
https://g35driver.com/forums/wheels-...ml#post5738449
Danielek
Oct 7, 2015 09:59 AM
mattdg35
Sep 14, 2015 11:28 AM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
AuAltima3.5
Sep 12, 2015 08:21 AM
Danielek
Sep 10, 2015 06:18 PM
