KCR Exhaust review (X02)
Old Jul 27, 2009 | 04:12 PM
  #451
xXHotelCrazyXx's Avatar
Nice clip jairen!
Old Jul 27, 2009 | 04:16 PM
  #452
turbodog's Avatar
For everyone complaining about the holes being different on either tips, could you not drill new holes to make them the same?
Old Jul 27, 2009 | 04:27 PM
  #453
Frankieg35's Avatar
You can get different tips and have them welded on..That's what I would do those tips look horrible..
Old Jul 27, 2009 | 09:29 PM
  #454
tom's_Z's Avatar
Yah you could do that, but then you would have to spend some time on crappy tips, so I had them swapped out.
Old Jul 29, 2009 | 08:33 AM
  #455
BostonG6spd's Avatar
i would prob get the FI 5" tips
Old Jul 31, 2009 | 11:29 AM
  #456
turbodog's Avatar
just bought this exhaust... I can post pictures once it's finished... if anyone wants to look at a 350z
Old Jul 31, 2009 | 11:54 AM
  #457
verilath's Avatar
for sure! I would like to see how it sits on a Z
  #458
tom's_Z's Avatar
There's a guy selling some pretty decent quality tips (5") on Ebay, I posted about them earlier.....
Old Aug 2, 2009 | 12:59 AM
  #459
Hydrazine's Avatar
Do you think these will fit?
They have a 2.5" inlet.
http://www.motordyneengineering.com/...components.php
Old Aug 2, 2009 | 01:03 AM
  #460
Jairen's Avatar
^I doubt those will fit. I would be cool if it did.
Old Aug 2, 2009 | 01:12 AM
  #461
tom's_Z's Avatar
They will fit. Mine are also 2.5 inlet, 4" outlet. The mechanic has to put them in the machine to stretch the tip out slightly, so it would slide over the 2.5 openings on the exhaust.
Old Aug 2, 2009 | 01:48 AM
  #462
Xet's Avatar
Xet
^do you have the cx?
i dont think it would fit the cx like plug and play because with the cx it has an inner tip that is about the same size as the outlet. if you were to cut off the 2.5 inlet on that tip, it would most likely be able to just slide over much like the given tip does. or you could cut the exhaust itself.
looks really good but 90 bucks a piece?!?! OUCH thats basically paying for half the exhaust again xD. if you cut off the inlet part and drill a hole on either side and send it to me ill post pics
Old Aug 2, 2009 | 03:10 AM
  #463
Hydrazine's Avatar
If it helps at all, these tips slip fit on 2.5" tubing.
Old Aug 2, 2009 | 10:36 AM
  #464
tom's_Z's Avatar
Yup, have the CX. The 2.5 inlet on the exhuast was identical to the 2.5 inlet on the tips I bought, so the tips wouldnt fit over the exhaust outlet (they were the same size). So the mechanic stretched the piping on the tips I bought very slightly, using a machine, and then the tips fit right over the exhaust outlet, and he welded from there. I didnt want to use screws.....so if you get tips for this exhaust with a 2.5 inlet, it might not be a DIY, i.e. you cant just screw it on.
If you got tips with a 2.75 inlet, problem solved!
Old Aug 2, 2009 | 10:39 AM
  #465
tom's_Z's Avatar
If they fit right over, cant see how they would be 2.5".....same size, right? I dunno
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
