Kinetix Velocity Manifold
Old Jun 3, 2009 | 10:49 PM
adths63's Avatar
Hey guys just another question i have
Im still learning so bare with me but does this intake manifold
http://www.kinetixracing.com/new-ssv...zg3503-06.aspx
...really give you up to 30 hp around 6800rpm ? Has anyone had expericene with this?...Also would a Motordyne 5/16" Copper Iso Thermal plenum spacer still work with the new intake manfiold (sorry if a noob question )
Thanks in advance !
Old Jun 3, 2009 | 11:02 PM
redlude97's Avatar
Let me ask you this, it says that it was performed on a stock 03 350z with no modifications. What nonrevup 03 350z motor do you know that can rev to 7000rpm? That should answer your question on how legitimate their claims are.
Old Jun 3, 2009 | 11:18 PM
GLuXuRy's Avatar
^^^bahaha nice catch .. redlude you always have smart post's .. keep it up !!
Old Jun 4, 2009 | 06:53 AM
adths63's Avatar
Ha wow very true , thanks
Old Jun 4, 2009 | 10:25 AM
Realtor's Avatar
Can't use plenum spacer and ssv. The spacer is for your oem plenum, which works at least it has dyno sheets showing improvement over stock.... Hope that helps.
Old Sep 14, 2011 | 09:32 PM
fredrik94087's Avatar
OP said 6800 not 7000.
I remember shifting at 6700 in my 04...can't be sure...I have 05 now.
Old Sep 15, 2011 | 02:43 AM
Vegas4DR's Avatar
all non rev are 6600 redline and 6800 rev limit
revup is 7000 redline and 7200 rev limit
HR is 7500 redline and 7800 rev limit
Old Sep 15, 2011 | 10:15 AM
Emart1290's Avatar
Has anyone actually had some experience with the SSV? Ive heard so many mixed responses from outside the forums im trying to clear some up before I make a decision. I'm running N/A of course with exhaust,HFCs, and cold air just trying to pull a lil more out of the band. Any comments?
Old Sep 15, 2011 | 11:32 AM
1hotvq's Avatar
i have an ssv and i would only recommend it if your going FI. if your NA then a mrev and spacer would a be much better choice.
Old Sep 15, 2011 | 06:50 PM
CLyons0203's Avatar
My car 05 G35 hfc, spacer, hr y pipe, coupe mid pip, 05 rev up box tuned. spacer vs manifold. same day, same dyno, manifold lost power thru the whole power band
Old Sep 15, 2011 | 06:54 PM
CLyons0203's Avatar
that was a street solutions manifold which is just like the kinetix
boostelevator
Engine - Intake/Fuel
12
Jan 12, 2016 11:35 PM
ncg35guy
Sep 26, 2015 04:04 PM
TNRocker
Sep 21, 2015 08:36 AM
HellaG35
Intake & Exhaust
Sep 8, 2015 10:02 PM
Freedz
Aug 28, 2015 07:38 PM
