Got a code, P1283
Old Sep 13, 2020 | 11:13 AM
  #31
Turbog35's Avatar
It's a 6speed manual sedan base model with some bolt ons
P1283 code
Can you get a p1283 code from an exhaust leak? I had the code come up when I had an exhaust leak and had my xhaust redone and the light was gone. 3 weeks later it came back on but I do have a new leak they need to fix prob crap welding because its new piping from the cats back. Any advice
Old Sep 23, 2020 | 02:04 PM
  #32
Turbog35's Avatar
P1283 code
I never had the code come up until the exhaust leak but I did change the cats but not the o2 sensors is there anyway to narrow it down. It says sensor 1 bank 2
Old Jun 19, 2024 | 12:16 AM
  #33
Dlope548's Avatar
G35x
Did u find out what this code was?
Originally Posted by dimentio1
nevermind, sucker came back on after 30 miles
after that what did u do? Did u find out what it was?
Old Jul 2, 2024 | 12:13 PM
  #34
Dlope548's Avatar
G35x
P1283 P1273 fix
Originally Posted by 4drmadness
Hey guys this was the code that came on. I reset it and it came on again after a couple days. I do have aftermarket headers and hfc. What do you guys think could be the problem.
Little late however for anyone currently experiencing this code figured I post.
P1283 turned out to be a mixture of things. Faulty fuel injectors bank 2 & A/F sensor 1 bank 2. Disregard OBD11 tests, as sensors can still be clogged even though ECM is reading proper fuel delivery. DTC detecting condition states - bank 2 shifted to lean side for specific period. Meaning your code is popping up sporadically. I swapped fuel injectors and it got rid of P1283 then PO174 popped, and that was A/F sensor. Changed that and bank 2 is no longer running lean.
Conclusion - P1283 with aftermarket headers can have something to do with A/F sensor. NOTHING to do with HFC. Can try defoulers on headers or swap for higher quality 02. ALSO it would have to do with fuel delivery so I would check fuel injectors/fuel rail/fuel damper for any clogs.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
KallDay86
Jan 8, 2016 12:42 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
Detailed Image
Sep 28, 2015 07:04 AM
vamarris
Sep 26, 2015 12:56 PM
