Those that use the 3" MAF....
After talking with Z1 today I ordered the black Samcon pipe and the silver 3" MAF housing...this should allow me touse my 9" filter I just bought...I will install everything but the MAF until I can head north to see Dave for a re-tune. I know it is bad karma to say it but after this I think I have done all I can as I am not doing FI, headers or cams.
![JAMIN](https://g35driver.com/forums/images/smilies/jammin.gif)
Check out this very short vid I made coming back from Va last weekend.
I'll post pics this weekend of what I'm going to do with my 3in MAF. (meaning filter and velocity stack)
I have not checked out the GTM site, if is that easy than I may do it! On the mustang transgo kits I had to drill the plate and swap check ***** around as well as swapping springs so this one sounds easier...I could get the mustang transgo kits for right around a $100, why is the one for G so much more if it involves less parts?
I'm going to have Dave do it sometime in Oct when it gets cooler. I have a 3in BPI flowstack with a 3in MAF adapter that I bought off ebay for $5. Check it out
www.bpinitiatives.com
I will check that link out as 03350Z said it was better not to attach the filter directly to the MAF housing. I will probably do the same thing and get it tuned in Sept.
I was confused with what the total price was of the Transgo installed..can you explain it?
Did you get it done in NC or Newprt News?
I have the 19" tires so more mass..
http://www.jhpusa.com/store/pc/viewP...idproduct=4300
I’m planning on getting that velocity stack and filter, the Z1 3” MAF housing and a 3” adapter from the housing to the intake. Should be able to get this done in November though, after I hear some feedback from you guys and after I replace my clutch, flywheel, and add a 3.9 FD.
