Test Pipe O2 Sensor LIGHT ON!!!!!!!!!!!!!
Old Oct 20, 2009 | 12:06 AM
niskyline77's Avatar
So I decided to get a used Stillen Test Pipe for my 07 G coupe. I found out after the installed that they were suppose to be for 03 to 05 coupe ONLY or 03 to 06 Sedan. I got a check engine light on today and don't know what to do. I expected that it will not pass Smog but this Check Engine Light is driving me crazy. Any way to fix this without pulling the fuse? I had assured that the O2 sensor were plug in as I did reviewed it with my mechanic before bringing the car down from the lift.
Please advice,
thank all,
Old Oct 20, 2009 | 11:27 AM
RaginRaj11's Avatar
You will definitely not pass smog with any sort of test pipes. You can try the O2 fix which involves using a spacer in each O2 bung and that might get rid of the CEL light.
Danielek
May 1, 2022 01:28 PM
06g35
Feb 14, 2022 05:59 AM
Video Share
Jan 31, 2017 04:00 PM
AT23
Sep 15, 2015 07:44 PM
