Port and Polish Plenum Assembly
Old Nov 25, 2009 | 11:52 AM
sexyrob's Avatar
There is a DIY plenum porting thread at my350 but I felt like sharing my project here too...
I got an extra set of the plenum assembly and began tearing it up in hopes of making a little extra power by letting my engine breath easier.
By the time I finish it will be fully port matched, and polished, and a good coat of paint will be put on the exterior to make my bay look pretty.
**Lower Plenum**
Casting Surface
Big casting flaw
Grinded off the top of the front runners
Before I started grinding
After around 30 mins
more than an hour of grinding at 80 grit
another 30 minutes at 120 grit
attempting to grind around the curve
Old Nov 25, 2009 | 11:57 AM
sexyrob's Avatar
** Lower Runners **
Before
Starting
Grinding more
front two nearly complete
showing bottom of runners
almost complete
finished
Old Nov 25, 2009 | 12:07 PM
DEMoLITIoN's Avatar
sweet
Old Nov 25, 2009 | 02:55 PM
viceversa's Avatar
Wow! looks really good man!
Old Nov 25, 2009 | 02:58 PM
Morovasa's Avatar
Looking Good!
Old Nov 25, 2009 | 03:01 PM
baskins87's Avatar
i want to know ur end results im thinking of this myself!
Old Nov 25, 2009 | 04:04 PM
LightsOut's Avatar
SIETESG
impressive
Old Nov 26, 2009 | 03:26 AM
RRYDE's Avatar
Looks like you are doing a great job, good details.
I did this to my plenum and I did notice a difference. Even my wife noticed the diffence and I didn't tell her what I had done.
Old Nov 28, 2009 | 02:54 PM
JSpec350GT's Avatar
Good job! Do you do this on TB too?
Oh and how would you measure the performance gain? I mean that's a lot of time spending and how we know if it's worth doing it?
Old Nov 28, 2009 | 03:57 PM
sexyrob's Avatar
had this posted on my350 for awhile, guess I'll put it up here.
Polishing:
Throttle plate polished (to 1500 grit)
Smoothed out all internal casting marks and got rid of the edge, Polished to 600grit
Old Nov 28, 2009 | 04:00 PM
sexyrob's Avatar
December 13th I have a dyno day scheduled. I will be doing two runs, one with the stock TB>Upper>Lower>Runners and one with my ported/polished version.
will have two dynos to show before and after.
Old Nov 28, 2009 | 10:28 PM
gabe3d's Avatar
Good job, it looks really well done.
How do you plan to port match the runners to the TB (it's oversized correct?) or do you just mean you will match the runners sizes between the collector and lower?
Old Nov 29, 2009 | 12:12 AM
sexyrob's Avatar
the TB isn't much bigger than the opening in the upper plenum, I didn't bore it out that much just smoothed the castings. I also did some griding on the upper plenum so its going to be size opening as the slightly "bored" out TB
Old Nov 29, 2009 | 12:37 AM
Tollboothwilley's Avatar
TB looks good. You had no problems with it calibrating correctly after reinstalling it?
Did you paint that...it almost looks like powder coating but I don't think you can PC a TB.
Old Nov 29, 2009 | 02:21 AM
sexyrob's Avatar
no problems calibrating, unfortunately it is paint... can't afford to powder coat and can't currently do it myself. There is no reason you shouldn't be able to PC a TB... just gotta make sure you strip it down to the core and tape off the places you don't want covered, same with painting.
Although, the paint is holding up surprisingly well, its very hard.
