Port and Polish Plenum Assembly
Old May 20, 2010 | 11:58 PM
  #61
bikinilust's Avatar
Heres some pix of what I did in the past...
and I did opt for the welding
Old May 20, 2010 | 11:59 PM
  #62
bikinilust's Avatar
lower collector was gasket matched
Old May 21, 2010 | 12:08 AM
  #63
bikinilust's Avatar
more than an hour of grinding at 80 grit
another 30 minutes at 120 grit
attempting to grind around the curve
what did you use to smooth out the bowl areas on both sides?
[exp: tool and bit]
And were you able to smooth out the entire length of each runner interior?
I tried just about everything and cant figure out which tool would be best. Or at least what type of bit to use
Old Oct 2, 2010 | 01:52 PM
  #64
sexyrob's Avatar
I used a rotozip for the big open areas with grinding discs
I used a dremel with a snake attachment for the runners
Old Oct 2, 2010 | 01:56 PM
  #65
sexyrob's Avatar
working on getting a big dyno session to test a bunch of intakes/plenums, check out my thread
https://g35driver.com/forums/dfw-g35...take-mods.html
wonder how well mine will do?
Old Nov 12, 2011 | 10:13 PM
  #66
artsVQ's Avatar
thanks for doing this write up what good pictures!
i just got my spare upper and lower plenum to play with i am going to fallow what you did
Marlin84
Apr 1, 2020 12:52 PM
jeffbdye
Jun 1, 2018 03:51 PM
prinny
Nov 22, 2015 11:07 PM
thechitoguy
Oct 1, 2015 05:25 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
