Helpp! cant remove Y pipe!!
Old Jan 6, 2010 | 11:10 PM
Sanclementeg35's Avatar
Exclamation Helpp! cant remove Y pipe!!
ive been trying to take of my Y pipe for 2 days now...
used two foot breaker bar... even a eletric impact gun and PB blast over night and 5 times the next day No luckk... ANY advise?????
Thanks
Old Jan 6, 2010 | 11:15 PM
SxExCx's Avatar
lefty loosy / righty tighty....duh
Old Jan 6, 2010 | 11:16 PM
thanks but i already know that.
Old Jan 7, 2010 | 06:22 AM
Blue Dream's Avatar
I drove ttrank's car solo
Sounds like you're going to have to cut the bolts.
See, that wasn't so hard..........
Old Jan 7, 2010 | 08:47 AM
TurTLe*'s Avatar
mini torch... simple way is to cut with a side cutter.
maybe drill thru the bolt
working on rusted on exhaust sucks *****
Old Jan 7, 2010 | 09:27 AM
lexusk8's Avatar
Pony up about $85, take the car to Midas and let them take care of it for you. That's what I did when I got my midpipe installed. Just not worth the hassle doing it yourself w/out a lift.
Old Jan 7, 2010 | 01:17 PM
DaveB's Avatar
Air tools or cut them off. I had to use my air tools to get them off. Worked easily. I attempted to remove them with a 20" breaker bar and I knew they'd start to strip or round off.
Old Jan 7, 2010 | 05:35 PM
Thanks for all of your input.
im taking it to one of my friends shops today
Old Jan 8, 2010 | 06:45 PM
nkjs77's Avatar
Spray lots of WD40 and let it soak for few minutes? But I'm sure you already knew that.
I just used half the can, just to install catback system on mine ('03 coupe), few days ago.
Old Jan 9, 2010 | 09:14 AM
InShAllAh's Avatar
I say funk it and just let that b1tch hang! ... LOL
Old Jan 9, 2010 | 03:30 PM
i finally got it off after 4 days of Pb blaster soaking.
Old Jan 10, 2010 | 12:01 AM
Tollboothwilley's Avatar
Good. I was gonna suggest soaking it every 10 min for a couple hours. Just have a few drinks and enjoy the smell of that rat ****. It works wonders. (you need more extension for better torque next time: works for me every time)
Old Jan 10, 2010 | 02:13 AM
TurTLe*'s Avatar
its rarely bout the torque, more about getting the socket on the rusted old bolts in my case anyways. a 2 foot breaker bar and a electric impact isn't very strong.
my air powered IR2135 puts out a claimed 1000ft/lbs couldn't get some off nor my 35 inch breaker bar. RUST > anything and everything
Old Jan 10, 2010 | 12:40 PM
I use a 3 ft breaker bar, and if that doesnt work I use the floor jack handle as a cheater bar. I've never had anything that I couldn't get off yet Get a lot of rust on the bolts here in Utah from the salted roads in the winter.
Old Jan 15, 2010 | 10:25 AM
Hydrazine's Avatar
Guys. If you ever run into a problem like this where you can't remove the nut off a rusty bolt, you can use an oxy/acetylene welding torch to help out.
Use the torch to heat the nut to cherry red. Once its red hot its ready to come off with very little effort.
No impact wrench, no breaker bars, no oil.
Danielek
May 1, 2022 01:28 PM
Red G Coupe
Video Share
Sep 6, 2015 06:45 PM
kevintandmd
Sep 3, 2015 06:41 PM
erich2780
Sep 3, 2015 03:23 PM
