Stillen Headers
Old Jan 22, 2010 | 12:53 AM
t-tire's Avatar
Stillen Headers
Hello, i was just wondering if anyone has had any experience with the stillen headers. I just want to know if there is any noticeable power loss in the lower RPM range? Thanks.
Old Jan 22, 2010 | 12:59 AM
pinkii's Avatar
didnt notice. But I got headers, HFCs and exhaust at the same time so I wouldnt really be able to tell.
Old Jan 23, 2010 | 08:18 AM
t-tire's Avatar
Okay. As of right now i have installed a Stillen high flow cat back system and will eventually put HFC and headers but i guess with an entire exhaust and then an FIC tuning afterwards no power should be sacraficed in the lower PRM range.
Old Jan 23, 2010 | 01:09 PM
liche's Avatar
Headers are generally a waste of money for the G35. Just stick to the HFCs and Catback and apply that money towards something else.
Old Jan 23, 2010 | 01:49 PM
t-tire's Avatar
really why? On Stillens web site they say it gains 11.5 hp at @ 6200 RPM and 18.5-lb.ft @ 3800 RPM.
Old Jan 23, 2010 | 04:10 PM
liche's Avatar
Because due to the high costs of installation (or aggravation if you do it yourself), its the worst bang for the buck - NA mods that is. Low gains and high cost installation.
Also, always be wary of manufacturer's claims with HP increases.
I had my car dynoed (before and )after putting a lot of bolt-ons including Stillen exhuast, spacer, intake, etc... and i didn't see squat in gains - at least compared to what claims the manufacturers made. Didn't really see any "real" gains until I went FI.
Old Jan 23, 2010 | 06:34 PM
t-tire's Avatar
so pretend you got free installlation, would they be a good power adder. I am mostly concerned about loosing too much power at lower RPMs. Also when you added all of your bolt-ons did you tune your car? Did that make a difference?
Old Jan 23, 2010 | 10:19 PM
vq35dedriver's Avatar
I personally have the stillen ss headers they got installed with the stillen cat back as well. I felt gains throughtout the power range without a tune and HFC's. Then added stillen HFC's and tune (osiris) then the actual gains are felt with
Old Jan 26, 2010 | 02:59 PM
OCG35's Avatar
the key is a tune...
If you add decent breather mods and they actually work - you will not benefit unless you have a/f corrected... in fact, you may run so lean that the ECU pulls timing and lose power.
To say a particular breather mod doesn't work (without tuning to take advantage of what it does) isn't relevant.
Some headers are more difficult to install that others... there aren't many mods that are good bang for buck - so after the low hanging fruit, the right headers aren't a bad consideration (if you don't mind the low gains for dollar equation).
Old Feb 4, 2010 | 01:42 AM
butkiss1's Avatar
Cant agree with u more OC
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
