HKS Rear Section: Install ?
Old Feb 9, 2010 | 11:23 AM
Matzo Ball's Avatar
Picked up HKS rear with the '03+ mounting brackets installed on it. How hard/how much damange would it cause to remove them as I have an '04 cuarently and dont need the extra fitting?
Old Feb 9, 2010 | 12:25 PM
SedanManBen's Avatar
I wasn't aware there was a difference! I have an HKS waiting on my front step at home.. I hope I don't have this same problem!
0.o
Old Feb 9, 2010 | 01:24 PM
sloppymax's Avatar
I had the HKS rear section installed for a while on my 06. I had to purchase the 03-04 bracket in order to mount it. I do not think you can use the 05 bracket, just need to reuse your current 03/04 one. It was designed according to the original fitment of the 03-04.
Old Feb 9, 2010 | 01:25 PM
Matzo Ball's Avatar
So I would just remove the bracket currently on this?
Old Feb 9, 2010 | 01:29 PM
sloppymax's Avatar
If you are sure that it is an 05/06 bracket then yes. Remove it and replace it with the one currently holding up your oem muffler.
Old Feb 9, 2010 | 01:30 PM
Matzo Ball's Avatar
It is another 03/04 b/c the previous owner had an '05x.
Old Feb 9, 2010 | 01:37 PM
AARONHL's Avatar
Soak the rubber hanger mounts with WD-40 so you can easily remove them (and re-use them if needed).
Old Feb 9, 2010 | 01:47 PM
Wannabe6MT's Avatar
-MN G Crew-
Just remove it. You dont need it as you already have one.
Old Feb 9, 2010 | 01:53 PM
Matzo Ball's Avatar
cool, just want to make sure.....
Old Feb 9, 2010 | 02:38 PM
Wannabe6MT's Avatar
-MN G Crew-
If. Idk though, it might be easier to take the one off your car and put the new one up. That was kind of a PITA to install.
jsimonk
Dec 22, 2023 03:49 PM
EPG35
Aug 16, 2015 04:52 PM
neight
Steering & Suspension
Aug 7, 2015 02:48 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
Soumilg
Jul 18, 2015 12:33 PM
