Advanced Resonance Tuning (ART Pipes)
Old Mar 3, 2010 | 03:00 PM
  #196
Tollboothwilley's Avatar
I am utilizing a Innovate LC-1 wideband in addition to stock O2 sensors. Currently have a bung welded on to the drivers side cat where the wideband reads from.
Old Mar 3, 2010 | 03:01 PM
  #197
DaveB's Avatar
Originally Posted by OCG35
he cant use same location?...
Not when the OEM 02 sensors are already there.
Old Mar 3, 2010 | 03:04 PM
  #198
GT-ER's Avatar
This is what I was about to say. Or you can take the stock narrowband and replace it with a wideband and have an LC-1 controller mimic the narrowband function so that both the ECU is happy and the wideband reads well.
Old Mar 3, 2010 | 03:05 PM
  #199
^^ some people replace a stock sensor with a wideband. The innovate can be programmed to send a narrowband signal so that you can utilize just the wideband and not stock but therea ren't a lot of people that have gone that route and some that did had troubles calibrating it properly. I just went with an easy setup by welding a bung...although I guess I could try using the narrowband signal feature.
Old Mar 3, 2010 | 03:48 PM
  #200
OCG35's Avatar
^^^ this is what I meant... I didn't realize you were using 2 locations.. I figured the original would have been replaced with wide-band...
I'm not all that familiar with the earlier year difficulties though...
Old Mar 3, 2010 | 03:51 PM
  #201
Jeff92se's Avatar
Red Card Crew
Using a wb to double as your oem narrowband seems like an expensive way to do it. aren't replacement WBs for the LC-1 a touch pricey?
Old Mar 3, 2010 | 03:53 PM
  #202
OCG35's Avatar
right now his concern is using the ART pipes...
the "economical" solution is keep his current setup...
Old Mar 3, 2010 | 04:00 PM
  #203
Jeff92se's Avatar
Red Card Crew
I agree with Tony on this. Welding in another bung for you to use the LC-1, is probably the most logical/economical solution.
You aren't using two WBs are you? Seems like if you just used one WB in place of just one o2 sensor, it would cause the calibration problems you mentioned.
Old Mar 3, 2010 | 10:43 PM
  #204
Just one WB. I think the problems that people have had are more with not setting the simulated voltage properly.
Using a WB in place of the stock sensor is probably MORE ECONOMICAL than spending time/$$ getting a bung welded but that would replace the sensor on my headers, not the ones on the HFC/TP.
Old Mar 3, 2010 | 10:58 PM
  #205
GT-ER's Avatar
Wideband sensors aren't all that expensive. I remember buy them at something like $60 a few years ago.
Old Mar 3, 2010 | 11:03 PM
  #206
OCG35's Avatar
thats crazy cheap!
Old Mar 3, 2010 | 11:23 PM
  #207
thats just the sensor. normally arond $80. but you will need a controller as well.
I would feel really bad hacking up these ART pipes to weld a bung...Its like destroying art.
Old Mar 4, 2010 | 12:02 AM
  #208
GT-ER's Avatar
Just checked out of curiosity and the sensors have gone up...cheapest I found was $96 in a quick 5 minute search. I remember me getting a few for $40 back in the days...lol.
Old Mar 4, 2010 | 12:40 AM
  #209
OCG35's Avatar
I just bought an OEM sensor - it was 120+ iirc...
*edit - I just looked at invoice - it was 150...
Old Mar 4, 2010 | 12:57 AM
  #210
Jeff92se's Avatar
Red Card Crew
OEM sensors are expensive because they have the oem harness attached. The same sensor w/o it is quite a bit cheaper.
The LM-1 replacement bosch 5 wire sensor is $80. About the same price as a generic sensor.
