NRG catch can install help
Old Mar 8, 2010 | 07:54 PM
  #31
Blue Dream's Avatar
I drove ttrank's car solo
No worries. I wasn't trying to start ****, just thought it was interesting that you would want to spend more on a used set than it would cost you to buy new.
Your install looks clean and your engine bay's sick. I'm still trying to decide where I'm gonna put mine. You have plenty of hood clearance on top of the can?
Old Mar 8, 2010 | 08:07 PM
  #32
CERBERUSlucid's Avatar
Thankx bro...yes the clearance is fine with the can there the only deal is that you need to shave down that piece of plastic in the center of your fanshroud...its the piece that holds the overflow hose on a 350z...other than that the position there is all good...LMK how yours turns out...=)
Old Mar 8, 2010 | 08:16 PM
  #33
antknee's Avatar
thats sick bro! if i know where to get the hoses i might get 4dr.s catch can..
Old Mar 9, 2010 | 03:37 AM
  #34
Dr. Ephil's Avatar
Forget waiting on the o-ring,I'll replace the pcv valve when I get it. Tackled the install over the weekend.
I posted my DIY over here:
http://www.niclub.ca/forums/showthread.php?t=1659
Let me know what you think on my install,thanks.
Old Mar 9, 2010 | 06:36 AM
  #35
Blue Dream's Avatar
Looks good. Now all you need are some braided hoses, and a polished z tube and a polished PS reservoir and.......................
You were right at niclub, it never ends.
Old May 18, 2010 | 04:30 PM
  #36
UPDATE: Well its been about 2 and a half months since I installed the NRG catch can and just a heads up to all you guys…
the stock gaskets that came with the catch can ended up leaking...=( not bad at all but still regardless it leaks...
so "use oil/gasoline resistant sealant on the bottom of the NRG can"
Old Nov 25, 2010 | 06:31 PM
  #37
856_reilly's Avatar
what if im getting oilfrom the drivers side tho. It all sounds good and looks nice but if i do all this it seems i'll still b getting oil sucked into my oil filter and s/c. from drivers side valve cover
Old Sep 11, 2011 | 10:54 PM
  #38
G35thrilla's Avatar
This is how mine is mousted in my 05 coupe and seems to be fine. No leaking and catching what it needs to catch
Originally Posted by CERBERUSlucid
Heres the placement I was thinking about... what does everyone think???
Old Apr 3, 2012 | 04:21 PM
  #39
Techre5's Avatar
Do any of you have an idea as to what kind of braided hoses I should buy? More specifically what size? and Where? Im getting the Greddy oil catch can.
gatorglaze
Sep 10, 2015 12:03 PM
Machine Head
Sep 4, 2015 07:22 PM
RA102223
Aug 15, 2015 09:24 PM
ghost_g35
Aug 7, 2015 10:31 AM
lemmy999
Jul 25, 2015 12:13 PM
