Intake Resonators
Old May 12, 2010 | 09:13 PM
Kaiten's Avatar
Intake Resonators
Interesting thing I found dating back to 2002. Basically states that in addition to quieting the intake, resonators also produce power. Most of us know we add the z-tube purely for the sound and then gain nothing or even lose power but for uneducated people like me, this explains why. Complete with pictures!
http://www.planetsoarer.com/resonator/resonator.html
Old May 12, 2010 | 09:32 PM
JBF's Avatar
JBF
interesting
Old May 12, 2010 | 09:38 PM
thescreensavers's Avatar
Mr.202?
interesting but people have dynod the car with the G-Tube and Z-Tube with no power gains or losses when swapping the two.
Old May 13, 2010 | 02:00 AM
DaveB's Avatar
I've been saying this for years, just because something looks restrictive doesn't necessarily mean that it is. You need to understand why the engineers made the part look the way it does. I use to be one of those people that thought intake resonators instantly means restriction. I did some research and realized that I was wrong for the most part. Most late model intakes are designed to reduce noise, improve throttle response, and improve power.
On 95-99 Maximas, removal of the resonator box closest to the throttle body will reduce power by up to 8whp in the mid range. These resonator boxes are actually Hemhotz resonators and they obviously improve power. http://www.freepatentsonline.com/6758304.html
There are also some intake tracts that were deliberately designed to choke the engine. My 94 Z28 was a prime example. In order to keep the Z28 from closely matching the acceleration of the same year Vette, GM added a significant restriction in the pipe between the throttle body and airbox. At one point in the tract, flow was impeded by over 50%. Adding a straight pipe in it's place instantly added 12whp/15wtq.
On the G, I ran the Z-tube for over 4 years. For giggles, I removed it one day and reinstalled the G-tube was a bit surprised to notice that the induction noise hardly changed and driveability/throttle response was the same, if not a little better. I sold the Z-tube. Tony at Motordyne has dynoed the G and Z tubes and there is no measureable power difference between the two.
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
vamarris
Sep 26, 2015 12:56 PM
