aftermarket ypipe ?
Old May 25, 2010 | 12:07 PM
  #31
MikeGrote's Avatar
the added torque seems like it might come from a bit more back pressure, is that right? maybe causing a tad more engine heat buildup? or is my logic incorrect there?
Old May 25, 2010 | 12:12 PM
  #32
jayk's Avatar
i had this exact setup with my stock g35 exhaust/stock CATs for for a few days (waiting for parts) and it defiantly smoothened out the VQ sound.
Old May 25, 2010 | 12:14 PM
  #33
MikeGrote's Avatar
thats what i dont want, i love the vq sound, just hate the rasp
Old May 25, 2010 | 12:16 PM
  #34
Hydrazine's Avatar
No, its not from back pressure. The resonator doesn't create back pressure. Its due to the resonance of the resonator.
Just a side note - Back pressure is never beneficial to this engine when NA. See this link for details on back pressure testing.
http://my350z.com/forum/intake-exhau...k-for-n-a.html
Old May 25, 2010 | 12:43 PM
  #35
MikeGrote's Avatar
thanks for that link, exhaust is a pretty simple concept, but gets complicated quick when looking at the details. i havent read that entire thread yet, but it seems like exhaust velocity near the engine is what should be most desired for scavenging, which makes power. good stuff. what exactly causes the rasp sound though???
Old May 25, 2010 | 01:24 PM
  #36
Hydrazine's Avatar
Shock excitation.
Basically anything that causes abrupt reflections. Sudden expansions or sudden contractions. And anything else causes a significant and sudden disturbance in the flow.
Old May 25, 2010 | 01:28 PM
  #37
MikeGrote's Avatar
i see, and can those excitations come from anywhere in the system, or is it mainly from pipes close to the engine? basically im asking if those excitations could come from the muffler in the back, or stricktly from the pipes farther upstream from that?
Old May 25, 2010 | 05:17 PM
  #38
Hydrazine's Avatar
The closer to the engine, the more likely it is to happen.
Old May 25, 2010 | 06:22 PM
  #39
MikeGrote's Avatar
thanks, i have stock manifolds, then kinetix cats, then the stock ypipe, so im guessing its the ypipe or i just need to tighten my cat bolts
Old May 25, 2010 | 06:34 PM
  #40
Jeff92se's Avatar
Red Card Crew
Maybe the cats are damaged? ie.. the brick is partially blown out and is creating that rasp
Old May 25, 2010 | 06:47 PM
  #41
MikeGrote's Avatar
i looked at them before i put them on, looked good as far as i could tell. before these, i had no rasp with gutted stock cats. i didnt gut the first bricks, but i removed the second brick in each cat so that the 02s wouldnt freak out. it was all fine for a while, then i threw a catalyst inefficiency code so i think one of the first bricks was damaged. put the hfcs on and have a ton of rasp, i will try and tighted the bolts this weekend
jeffbdye
Jun 1, 2018 03:51 PM
Blue Dream
Dec 5, 2015 10:56 AM
Fox843
Nov 7, 2015 05:43 PM
Learned Hand
Oct 1, 2015 09:02 AM
