aftermarket ypipe ?
Old May 21, 2010 | 01:15 PM
MikeGrote's Avatar
aftermarket ypipe ?
do the aftermarket ypipes add or cut down on the rasp?
i have stock exhaust except for kenitix hfc. just want the rasp to leave
Old May 21, 2010 | 01:31 PM
Swivel's Avatar
Moderator
Some opinions here:
http://www.myg37.com/forums/intake-a...-hfc-rasp.html
Old May 21, 2010 | 01:35 PM
HenryLee's Avatar
I think an aftermarket y-pipe would create more rasp. But a 350z HR y-pipe might help things flow better.
Old May 21, 2010 | 01:41 PM
Jeff92se's Avatar
Red Card Crew
The only things that I've read so far that will to this:
1) Using Motordyne's resonated test pipes (they don't create rasp in the 1st place)
2) Magnaflow resonated X pipe (but you'd have to be able to use a 2in / 2 out configuration. But I don't see why you can use it. Just Y it back into 1 pipe after the Magnaflow
Old May 21, 2010 | 01:48 PM
MikeGrote's Avatar
im trying real hard to find an HR pipe, link for the magnaflow x?
Old May 21, 2010 | 01:52 PM
Jeff92se's Avatar
Red Card Crew
I might have a 370z / G37 Y pipe.
Search threads I've created in this section. Been discussed at length + a picture.
Old May 21, 2010 | 01:54 PM
MikeGrote's Avatar
the 370 ypipe has smaller inlet diameters
HenryLee's Avatar
You cant add an X-pipe to a stock exhaust. You can only add an X-pipe to a dual flow style exhaust.
Old May 21, 2010 | 01:58 PM
Jeff92se's Avatar
Red Card Crew
Wrong. It's not been done yet.
HFCs -> X pipe -> Y -> stock exhaust.
Bolt up? No. Easily done? Yes. Might have to move the stock resonator down a bit but who cares?
Although after that much trouble, I'd probaby merge the X pipe into a larger single. Like a 2.75" or something. Each X pipe in/outlet is 2.25"
Or if your HFCs have 2.5" in/outlets, you can opt for a magnaflow unit sized at 2.5" easily enough.
Old May 21, 2010 | 02:03 PM
HenryLee's Avatar
^ Your gonna install an X-pipe between the HFC's and y-pipe? I dont get how thats gonna work. Its def not cost effective. The person will end up making a custom exhaust.
Old May 21, 2010 | 02:07 PM
Jeff92se's Avatar
Red Card Crew
No. HFCs -> X pipe -> Y COLLECTOR -> rest of the single exhaust. (but again, I'd use something larger than the stock exhaust (2.5?) if I were going to that much trouble already
Old May 21, 2010 | 02:13 PM
Jeff92se's Avatar
Red Card Crew
check this out. This is a modded Y pipe for the back end of a GTR.
They use it ----> then 2 out. But why not use this design in reverse?
HFCs --> Y collector+resonator --> rest of the system
Motordyne's Y pipe has this option but with a cat. Not sure if they offer a resonator in there also.
But a custom one would be EASY to fabricate if you can find a good resonator.
Old May 21, 2010 | 04:13 PM
MikeGrote's Avatar
whats the midpipe inside diameter?
this is a good idea, but seems like it will all have to be custom after the cats and that might be more work than im looking to do now. plus a bigger exhaust is only benefitial if you are modded more, all i have is a plem spacer. it can actually hurt power if the exhaust is too big for the engine
Old May 21, 2010 | 04:20 PM
Jeff92se's Avatar
Red Card Crew
If you ONLY care about cutting rasp, you could cut open your stock 03 Y and weld in a resonator. Looks to be more than enough room to do that.
But in reality, I'd try to usa a better designed Y and put a resonator in that. But that would mean moving your exisiting resonator down some. Not too bad.
Gotta bite the bullet if you want to innovate.
You could try a ginormous 03 sedan suitcase mid pipe and see what happens
Old May 21, 2010 | 04:44 PM
Beebo's Avatar
do you have a vid of the rasp?
