Stillen HFC + Stillen Catback Exhaust = ahhhhhh!
Eh folks. 06 AT Coupe.
(EDIT: I encourage those of you with rasp problems with Stillens to continue to read to the end... perhaps I have the solution to your issue in the last post. I think I've nailed it.)
Well, sad to say that against my better judgment (Was leaning towards MD) I was pursuaded to install the Stillen HFC and dual exhaust. As a result, I've found that I've had a pretty raspy tone and suffice to say that was absolutely NOT the objective. Lots of snot- a pretty noticeable increase in torque and horsepower with the addition of a COBB tuner and some dyno time... but NOT happy with the sound at all.
I'm relatively new to the options available to cut the rasp out- so what I'm wondering is if there are resonators that you can install into the Stillen system somewhere (like from MD) that will eliminate it? I know the MD system is more modular (which I liked in the beginning) and I'm not sure Stillen is quite as flexible.
Also, have other people with the same combination had the same problem- or do I perhaps have a leak somewhere that I should start looking for?
Thanks
Thanks
What other breather mods do you have?
Did you order everything new from Stillen?
I was also looking into the same exhaust and HFC.
I have the stillen intake / z tube, an MD 5/16ths isothermal spacer and then the above mentioned. The rasp isn't horrible... but it's bad enough that I'm looking into solutions.
I was just reading about that. Saw some good things about Kinetix too... I'm also looking REALLY hard at these new ART Pipes from MD... Though the 560 price tag is daunting.
I got a line on a set of Ultimate Racing High Flows Cats- apparently ceramic core for a 350z... Any idea about those?
eno
eno
Ok you gotta get the Magna Flow Dual in Dual out muffler thats listed in the previous post , then cut out the lame Stillen X pipe , then cut out the lame *** Stillen resonators (swap with straight pipe) . the rasp will be gone ! At this point you could run RESONATED test pipes.
Also check this link for sebring mufflers , Sebring makes the Fast Intentions exhaust.
Dude your done
1.Magna flow
2.cut xpipe
3.replace Stillen X withh Manga flow
4. Kill Stillen resonators
5. replace with straight pipe 18"
6. Kill Stillen Mufflers
7. replace with Sebring Mufflers
8. Get the MD Art pipes or at least Fast Intentions RESONATED test pipes.
9. DONE
These are the mufflers for the Sedan
https://g35driver.com/forums/private...m&pmid=3123838
it worked for me
Relax main , My old set up was stillen headers , stillen HFC's , stillen gen 2 (sedan) I followed this thread to a tee and lost 89% of rasp . BTW i now run art pipes and still no rasp check the link.
https://g35driver.com/forums/private...m&pmid=3111276
Iopened the link and posted here sorry bout that.
read ur post on the rasp problems with the Stillen exhaust, I have 2006 sedan with stillen headers ,Kinetix HFC's ,stillen gen 2 . the stillen muffler fell apart , so i threw on the magna flow dual in ,dual out muffler , like yours , the sound is a little deeper than the stillen , but the rasp ...... o h my god ... it sucks , so ur saying 2 scrap the stillen resonators , but wat do i replace them with??
i replaced the stillen x pipe and resonaters with one magnaflow dual in dual out muffler
I lost pretty much all rasp with this mod....with topspeed headers [ceramic coated], berk metallic HFCs, 1/2 motordyne spacer, and custom intake.
I dont mean to be a post ***** but , my rasp sucked so bad i couldnt take it.
This magna flow answer really works , I have two magna flows on my g and I love It , and so so every one who hears it Bottom line ......... it works. BTW power was not affected, Ijust got Dynoed at Church with the Art pipes 297 whp & 266 ftlbs
