NEW! Takeda intake
Old Sep 1, 2010 | 07:35 PM
antodiaz's Avatar
Originally Posted by DaveB
This is the design I've been talking about for ages. It's good to see someone actually build. I agree though, metal intake pipes suck. That's a bad choice on their part. The other issue is that the OEM accordian peice in the intake serves a purpose, to add flexibility to the intake as the motor rocks in it's mounts. The engine can rock violently from side to side on launches and shifts. Without the accordian, you risk snapping the plastic chassis stay on the OEM front airbox and/or having the intake tube get pulled of the TB.
I'll buy this intake if three people post consistent 5whp+ gains across the entire powerband. Otherwise, I'll stick with my OEM Frankenstein setup.
Yeap it will be perfect if they sale just the filter and airbox so you can use it with a z-tube that is plastic and uses the OEM accordian pieces. I'll probably get it next month I'm gonna try it with the metal intake for a little bit and see how it goes if not I'll just stick the z -tube back in there.
Old Sep 1, 2010 | 07:55 PM
Jeff92se's Avatar
Red Card Crew
It's interesting and I like it. But not at the price. Anyone have the filter size?
I'm running a frankie rev up v-stack oem but I have no problem running my stillen. Like I've said, it's not open to the hot engine bay. The portion of it that's open isn't accessible to the engine heat.
Old Sep 1, 2010 | 07:58 PM
saywat?'s Avatar
u kno how theres the heat issue but since the oem is setup so that air is pulled in from the outside as long as u keep those peices installed it doesnt take car of some of the heat issues?
Old Sep 2, 2010 | 01:24 PM
DaveB's Avatar
Not when you're in a lot of stop and go traffic or traveling at speeds less than 40mph. The pipe will get scalding hot when ambient temps are over 80 and you're driving in stop and go. It's not a huge deal from an air temp standpoint though because the air is moving at a rate through the pipe that it's not going to take on much heat as it travels through the hot pipe. That's why I think whole intake manifold cooling stuff is so silly. The biggest issue I see with the metal pipe is that it will heat soak the MAF sensor possibly making the MAF think ambient air is warmer than it really is.
Old Sep 2, 2010 | 03:37 PM
saywat?'s Avatar
someone should email the comp and ask them to make a cone filter converter type rig to connect to the stock tube. i would love to get the intake sound that im used to without the heat soak issue. id gladly pay $100 for a setup lol
Old Sep 2, 2010 | 03:53 PM
Jeff92se's Avatar
Red Card Crew
Just wrap the tube or something is one is that concerned about the metal.
Old Sep 2, 2010 | 10:18 PM
antodiaz's Avatar
Im pretty sure if you get a MAF sensor adapter you should be able to connect to the z tube.
Old Sep 2, 2010 | 10:20 PM
saywat?'s Avatar
^^yea i kno but i jus like the enclossure and how it uses the oem ducts. btw with this kit since the filter is enclosed will it still make the aftermarket intake sound?
Old Sep 3, 2010 | 12:16 AM
antodiaz's Avatar
Im pretty sure it will. I can't wait to get mine probably next month
Old Sep 3, 2010 | 12:54 AM
BrOun's Avatar
DaveB
I hope the designers took that into consideration when mocking this up. I don't see any extra mounts for support in the pic's. However I'm just summing that the non metal connecting pieces should give us ample room.
Jeff92se
you mean wrap it up w/ the same things used for AC pluming?
saywat?
I've seen adapters on the Apex site for there cone shaped filters. You'd have to get the right size for it b/c there are several adapters & I've read on this site that the Z adapter works for Z/G tube from Apex.
antodiaz
I'm with you on this one... I'll order mines when I get paid too. If anything I'll just have to get a Ztube & mod some adapters to it. Good thing FL has another 5 months of summer left to test heat temps w/ another metal piece in the engine bay.
Old Sep 7, 2010 | 08:34 PM
saywat?'s Avatar
after staring at this intake setup i dont see how this is different than the stock setup if u really look at it lol. its like wat most people already do with the stock setup but with the z tube
Old Sep 9, 2010 | 07:08 AM
cgk-68's Avatar
i am new to this forum,
Doing my research for an intake for my 08 G35X, this Takeda product that uses the factory box does it have a model# because i can't find on their web site. So far for best gains i found where the Injen and stillen, it looks good but i don't wish to remove the bumper and increase the chance of hydrolock.
any suggestions..thanks
Old Sep 9, 2010 | 08:19 AM
vp-g's Avatar
from the looks of it the 06 airbox and ztube with K&N filter is the best set up. Why spend all that money and get the same results with stock set up? looks? not worth it for me..
Old Sep 9, 2010 | 11:22 AM
Tollboothwilley's Avatar
I have a friend with the AFE intake on his Z. Its a well put together intake with great heat shielding. I'm sure this is of the same quality.
Old Sep 9, 2010 | 02:20 PM
  #30
antodiaz's Avatar
I'm sorry buddy but this intake is only for 03-07 coupes and 03-06 sedans. You have the HR engine with the dual intake. Lets see if they come up with a version for HR engines.
