Exhaust problem
Old Nov 21, 2010 | 02:04 PM
hL.'s Avatar
hL.
Exclamation Exhaust problem
I tried searching for a solution but nothing. Hope you guys can help me out
So yesterday while my car was running in idle from a cold start (-15 C over here) I noticed fume was only coming out from ONE of the two exhaust tips on the sedans. Has this happen to anyone?
Much help appreciated
Old Nov 21, 2010 | 02:18 PM
TORETTO's Avatar
Fume? As in smell was coming out from only one? If so, how'd you figure it was only coming out of one when they're next to each other on the sedan lol.
Or fume as in the water steam (white smoke) was coming out from only one? If so, it could just be that water was in one of them, but not the other (or not enough to cause noticable steam). I know my G35 (coupe) sometimes had white smoke coming out of only one of them or sometimes both would release steam, but one would have a significantly more amount than the other. I wouldn't worry about it unless you hear or feel a difference in driving. If anything, something small might have gotten in the tip of the exhaust and is blocking the flow. Just rev the car and see if something pops out lol.
Old Nov 21, 2010 | 02:19 PM
TIAN's Avatar
Hold The Line
Exhaust leak. Might have a blown exhaust gasket somewhere. Cheap fix
Old Nov 21, 2010 | 02:22 PM
TORETTO's Avatar
Is this a 2nd gen sedan? I thought the 1st gen had a single muffler with dual tips. Therefore a blown gasket would likely affect both tips?
Old Nov 21, 2010 | 02:27 PM
TIAN's Avatar
Hold The Line
He didn't specify on year. He may or may not have a stock exhaust
Old Nov 21, 2010 | 02:34 PM
TORETTO's Avatar
I just did the obvious and checked under his username lol.
Old Nov 21, 2010 | 03:25 PM
DaveB's Avatar
The first gen sedan muffler has a flap in it that opens under heavier loads. This variable design improve throttle response and low-end power. It's the same design that was used on the R34 GTRs, most single muffler BMWs and Benz's.
Old Nov 21, 2010 | 03:47 PM
hL.'s Avatar
hL.
Sorry, I meant the white smoke.
Stock exhaust on an 03 sedan
Well that's reassuring! So it's normal for our sedans during idle right?
Old Dec 11, 2010 | 05:59 PM
bulletproofpat's Avatar
It should be fine. Mine did that during the winter too.
Spartan268
Aug 20, 2015 09:14 PM
chinee
Aug 8, 2015 10:11 AM
Terry_G35
Aug 4, 2015 02:38 PM
newg37
Jul 26, 2015 09:32 AM
si_driver
Jul 14, 2015 12:29 PM
