Exhaust leak?
Old Dec 20, 2010 | 02:57 PM
Gtrpnoyracer's Avatar
Exhaust leak?
I was just outside and i noticed my hks exhaust (when on) was making a noise that sounded like air coming out of a tire, but it was coming out of the exhaust. it wasn't constant but its not like the noise would fade, either, it would turn on then off etc....just wanted to know if this was normal or something? I know it's not from my plenum spacer because it's comin out from the bottom. Aiight lmk
Old Dec 20, 2010 | 03:02 PM
gary c's Avatar
Unless you've hit the exhaust system it's probably a gasket, take it to your local muffler shop and get it fixed.
Gary
Old Dec 20, 2010 | 03:15 PM
You know That reminds me. The shop I went to told me that I didn't have to install these two gaskets yet in the front in between the catalytic converters so maybe I need to switch the stock ones with the ones for my hks exhaust. And yeah I didnt hit it so I hope that solves it. I hope they won't charge me for labor
Old Dec 20, 2010 | 04:06 PM
Algy's Avatar
If it sounds like a hissing noise just going off randomly and then stopping for a few seconds an then back on again and it's under your car... It should be normal. My g35c does the same exact thing with the stock exhaust and my Minsk exhaust so I wouldn't worry.
Old Dec 20, 2010 | 07:29 PM
Are you sure that's normal? I have two gaskets that I still need to swap in between the stock cat and downpipe because the place I had it installed at told me to use the stock one for now until it wears out. But if others who has an hks stock or another exhaust hear the hiss sound going on and off randomly and say it's normal then I'll take your word for it
Old Dec 21, 2010 | 01:36 PM
Higrev's Avatar
I would just replace the gasket as my first step of fixing it... rather than playing the guessing game.
Old Dec 21, 2010 | 01:41 PM
SkylineGTR2789's Avatar
Mine does it too sometimes, but only when i go from D to Manual mode .. i can switch it back n forth and everytime i go in manual mode it makes that hiss sound but i can only really hear it if im against a wall
Old Dec 21, 2010 | 05:43 PM
P-JDM's Avatar
Mine has done this from day one as well. Never figured out where it came from and never hurt me any so just left it alone.
Old Dec 21, 2010 | 11:12 PM
i actually went to the shop i had it installed at and they said that the aftermarket gaskets actually wear out way faster than the oem ones and they said it's normal so its all good now
Old Mar 7, 2011 | 09:21 AM
Mike9's Avatar
Does anyone know where I can order all new gaskets for the hks hi power exhaust I just bought? The gaskets look in rough shape so I'm going to get new ones..
hrdwirk1
Oct 2, 2015 06:34 PM
gatorglaze
Sep 19, 2015 12:06 PM
Moskvitch
Sep 14, 2015 10:15 AM
UT G35
Sep 3, 2015 03:58 PM
